How to diagnose service 4WD message? - Page 2 - JeepForum.com
post #16 of 45 Old 09-18-2009, 06:57 PM
HurriJeff
2013 WK
Drop off on Saturday AM. They will probably call me on Tuesday and I'll let you know. Remind you to tell the evaporator story !
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #17 of 45 Old 09-19-2009, 12:17 PM
kentman
kentman's Avatar
2006 XK Commander
Originally Posted by braleyk View Post
my message went away when i replaced the front diff solenoid and the wire harness 6 months ago. hope this helps
Not what I wanted to hear. I just bought both solenoids for the XK, and I was going to start with replacing the rear one first since it looks easy to do. The front diff looks harder. The cover is mounted to a cross member. I was hoping that replacing the rear one would do the trick so that I could avoid popping the cover off of the front one.
'06 XK Limited, 5.7L, QD II, Black, 169K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 129K
kentman is offline
post #18 of 45 Old 09-19-2009, 05:32 PM
HurriJeff
2013 WK
Wow Kentman, did you get a code for solenoid? How much were the solenoids ?? Mine turned out to be a $35.00 left rear wheel sensor. Of course I had to spend $100 to have the scan done and $80 labor to install it. I decided ti just let the dealer do it.
Previous Jeeps:
post #19 of 45 Old 09-20-2009, 05:04 AM
kentman
kentman's Avatar
2006 XK Commander
No codes. The solenoids are just a hunch. They were $23 each shipped. I figured that I would give them a try first. If those do not do the trick, I will then take it in to get the system scanned. I hate systems that require a special dealer scanner that costs thousands of dollars on the open market.
kentman is offline
post #20 of 45 Old 09-23-2009, 12:42 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Mine just started showing the warning a few days ago.
It's done it a couple of times before but the warnings always went away after a few starts.
It's been 5-6 starts and 60 or so miles and it's showing. I'll start checking for loose/worn wires tomorrow.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #21 of 45 Old 09-24-2009, 09:36 PM
kdawgFL
2005 WK
mine popped up a couple days ago the mechanic couldnt get any info said take it to the dealer to get the flash update i read about on the forums.
kdawgFL is offline
post #22 of 45 Old 09-25-2009, 05:11 AM
kentman
kentman's Avatar
2006 XK Commander
I got the flash update, and it did not help me.
kentman is offline
post #23 of 45 Old 09-25-2009, 06:45 AM
BonesWK
2006 WK
did you end up changing the solenoids? I have had a dealer tell me it is the front solenoid, but was going to charge me 6 hrs labor... is it that big of a job?
but then part of me thinks its just a bug, because I have had the message on and off for the 2 years I have owned it. even after the TSB was done.
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #24 of 45 Old 09-25-2009, 08:22 AM
LJS8510
LJS8510's Avatar
2015 WK
When I finally got my "4 wheel service " checked out.
The dealer said it showed a short triggered it, but they could not find what caused the short.
This happened about 1/3 way thru a 5000 mile trip and all has been well with it since.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #25 of 45 Old 09-25-2009, 02:46 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I thought that mine was due to low oil in the front diff. Resealed, refilled. Still get the warning. Tried disconnecting the battery for 1/2 hour. Still get the warning. Tried the 3x off on trick and no codes shown. Dashhawk shows no codes.
89 GW w/plow
wookiee is offline
post #26 of 45 Old 09-26-2009, 10:13 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I've read on other sites that dirty speed sensors at the wheels will give the warning.
I had just gotten off a nice long off road trek when the warning came on. So I'll try hosing off the sensors tomorrow.
89 GW w/plow
wookiee is offline
post #27 of 45 Old 09-27-2009, 07:58 PM
kentman
kentman's Avatar
2006 XK Commander
I am still waiting for the shipment of my solenoids.
The front certainly looks more painful. Six hours sounds a little crazy to me. The differential cover is mounted to a cross member. You will have to unmount the cover from the cross member. Then, you should be able to get it off.
kentman is offline
post #28 of 45 Old 09-27-2009, 09:25 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I took me 2 1/2 hours to get the front diff cover off and about 1 hour to get it cleaned, resealed & reinstalled.
There's one cover bolt that's a pain to get to, even after dropping the diff as far as it would go.
http://www.jeepforum.com/forum/f67/d...ential-863751/
6 hours by a pro is way too much!
89 GW w/plow
wookiee is offline
post #29 of 45 Old 09-28-2009, 04:44 AM
kentman
kentman's Avatar
2006 XK Commander
Where exactly is that connector, and how do I ensure that I do not break it?
I will probably wait until I am due for a fluid swap to do the solenoids. I have another 12K miles until the next swap on the XK. The fluids are not cheap, and I would hate to throw away perfectly good fluid. I will just keep an eye on level between now and then. It will take me about a year to get another 12K.
kentman is offline
post #30 of 45 Old 09-28-2009, 11:19 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
It sits on top of the differential.
I slid the red tab back and tried pulling the plug but it didn't move, so I tried using a screw driver, and then it broke. Not doing what I did will ensure that you don't break it the way I did, but you may find another way to break it.
89 GW w/plow
wookiee is offline
Service 4WD System message being displayed kunzet WK Grand Cherokee & XK Commander Forum 44 03-24-2016 04:26 PM
Service 4WD message on dash madmarchhare WK Grand Cherokee & XK Commander Forum 7 09-22-2008 02:02 PM
'Service 4wd Switch' error message in 94 ZJ DonPud4x4 ZJ Grand Cherokee Forum 1 02-07-2007 09:44 AM
Perform Service Message? WhiskeyThrottle ZJ Grand Cherokee Forum 7 09-17-2003 08:28 PM
Service 4WD Switch message Charlie93GC ZJ Grand Cherokee Forum 0 02-05-2003 08:08 PM
