How to diagnose service 4WD message? - JeepForum.com
post #1 of 45 Old 08-23-2009, 01:48 PM Thread Starter
crashcraddock
The service 4WD message is flashing on my sister's 05 WK Hemi and has been for some time. How do I figure out what my be wrong? The WK only has 42K on it.
crashcraddock is offline
post #2 of 45 Old 08-23-2009, 03:54 PM
merlinTec
merlinTec's Avatar
Software level of the FDCM needs to be the first check and make sure it's up to date. Then will need the code it is showing so we can help what to check from there.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 45 Old 09-14-2009, 07:12 PM
HurriJeff
2013 WK
Mine gave me that same message today. First came "Service 4wd", then came "the "Electronic Brake" error. The ABS light came on and the traction control light came on. I disconnected the battery for 20 seconds and then operated as normal. After about 250 feet of driving all the lights went off and have been off for about 30 miles now. My question is.. Will a shorted wheel sensor cause this error? I did notice at one time that the insulation on those wheel sensors had been rubbed abut I have not checked them since.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #4 of 45 Old 09-15-2009, 12:39 PM
merlinTec
merlinTec's Avatar
Hi
Yes it could fault codes would confirm this.
post #5 of 45 Old 09-15-2009, 02:41 PM
Rwebber77
2005 WK
"Service 4wd" was a common problem in my '05 Hemi until I changed the failing ignition switch a month ago. Haven't seen it since!
5.7 Hemi, OME HD, 1.25" spacers, 265/70/17 Revo 2's, Volant CAI, Gibson Catback, SCT engine management, Superchips piggy back with trans app, 3/4" front shackles
Rwebber77 is offline
post #6 of 45 Old 09-15-2009, 05:00 PM
LTrainGC
2005 WK
I have the "service 4wd system" message up all the time now. I hooked up my superchips programmer and got code C141D. I have narrowed my problem down to needed a new solenoid for the ELSD in the rear axle.
If you bring it to an autozone or anywhere like that they can hook up a scanner and give you the code to help you narrow down your efforts a bit.
-Frank the Tank-
-2005 Jeep Grand Cherokee Limited-
- 5.7L HEMI/QDII/Superchips/AEM Brute Force/MBRP/RRO/Bilsteins/32s -
LTrainGC is offline
post #7 of 45 Old 09-16-2009, 11:24 PM
LJS8510
LJS8510's Avatar
2015 WK
I had similar 4 wheel service warning but I also had a nasty smell like something burning.
I was also in low gear and used hill descent.
I shut it off took it out of low and the warning went away as did the smell. So far about 1000 more miles no problems. I have not tried the hill descent again yet
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #8 of 45 Old 09-17-2009, 12:04 AM
braleyk
2005 WK
my message went away when i replaced the front diff solenoid and the wire harness 6 months ago. hope this helps
'05 WK HEMI Limited QDII - 970JEEPERS
braleyk is offline
post #9 of 45 Old 09-17-2009, 11:27 AM
Roloc
I had this same message a couple weeks back. I took it in and they replaced the 4x4 actuator under warranty. Haven't seen it since. So I think it can mean a lot of different things. The only real way to tell is to look at the codes.
Also found out about Jeeps $100 deductible on a power train warranty... which is really lame.
Roloc is offline
post #10 of 45 Old 09-17-2009, 12:32 PM
LJS8510
LJS8510's Avatar
2015 WK
were any of you using low gear or notice a smell ?
LJS8510 is offline
post #11 of 45 Old 09-17-2009, 12:34 PM
Roloc
Nope I was going about 70mph about 3 hours into a 4 hour trip.
Roloc is offline
post #12 of 45 Old 09-17-2009, 04:51 PM
HurriJeff
2013 WK
My question is this... I had my local auto parts people give me a free ODBII scan and nothing showed. Should it have showed that I have bad sensor, solenoid etc or will that have to be done with StarScan? Second, if the wheel speed sensors fail, would that fault show up on ODBII, or will I need to have the ABS computer scanned for those ?
Previous Jeeps:
post #13 of 45 Old 09-17-2009, 05:28 PM
Roloc
Well then I would say you are one of the lucky ones. There is a TSB to do a flash on the system that fixes an erroneous displaying of that message.
http://www.wkjeeps.com/wk_tsb.htm#TRANSMISSION
Roloc is offline
post #14 of 45 Old 09-17-2009, 06:57 PM
HurriJeff
2013 WK
As for me.. mine is not erroneous.. I've got all sorts of differential binding. When I turned into my driveway this evening my Jeep was hopping around like I was in 4 low. Tire dragging and the whole thing. Not a good feeling. Loud clunking in the front and rear axles. There is a real problem here for sure.
Previous Jeeps:
post #15 of 45 Old 09-17-2009, 09:26 PM
Roloc
No codes and it is doing all of that stuff? I would take it to a dealer, or someone who knows jeeps really well.
Roloc is offline
Service 4WD System message being displayed kunzet WK Grand Cherokee & XK Commander Forum 44 03-24-2016 05:26 PM
Service 4WD message on dash madmarchhare WK Grand Cherokee & XK Commander Forum 7 09-22-2008 03:02 PM
'Service 4wd Switch' error message in 94 ZJ DonPud4x4 ZJ Grand Cherokee Forum 1 02-07-2007 10:44 AM
Perform Service Message? WhiskeyThrottle ZJ Grand Cherokee Forum 7 09-17-2003 09:28 PM
Service 4WD Switch message Charlie93GC ZJ Grand Cherokee Forum 0 02-05-2003 09:08 PM
