How to change spark plugs on 5.7l ? - JeepForum.com
post #1 of 2 Old 04-18-2009, 12:20 AM Thread Starter
daaaaaan
I've tried searching, but havnt found a good write up on how to change the spark plugs on a hemi.....I figured with how common of a "diy" type project this is for people to do to save some money, somebody who have taken the time to make a nice write up with step by step instructions for the not-so-mechanically inclined.....
So I'm just curious to as if there is such a instruction set out there? If not, i'll make one soon.
2012 Overland 5.7L
daaaaaan is offline
post #2 of 2 Old 04-19-2009, 06:25 PM
NewJeepOverland
2008 WK
Instructions found
I found it:
Removing plugs - 5.7L and 6.1L engines
5.7L note (2005 models only):
Before removing or disconnecting any spark plug cables, note their original position. Remove cables one-at-a-time. To prevent ignition crossfire, spark plug cables MUST be placed in cable tray (routing loom) into their original position. See diagram and information below.
Each individual spark plug is located under each ignition coil. Each individual ignition coil must be removed to gain access to each spark plug. The coil mounts to the top of the valve cover with two bolts. The bottom of the coil is equipped with a rubber boot to seal the spark plug to the coil. Inside each rubber boot is a spring. The spring is used for a mechanical contact between the coil and the top of the spark plug.
1. Remove necessary air filter tubing at throttle body.
2. Prior to removing ignition coil, spray compressed air around coil base at cylinder head.
3. Depending on which coil is being removed, the throttle body air intake tube or intake box may need to be removed to gain access to coil.
4. Unlock electrical connector by moving slide lock first. Press on release lock while pulling electrical connector from coil.
5. Clean area at base of coil with compressed air before removal.
6. Remove two mounting bolts (note that mounting bolts are retained to coil).
7. Carefully pull up coil from cylinder head opening with a slight twisting action.
8 Remove coil from vehicle.
9. Prior to removing spark plug, spray compressed air into cylinder head opening. This will help prevent foreign material from entering combustion chamber.
10. Remove spark plug from cylinder head using a quality socket with a rubber or foam insert. Also check condition of ignition coil o-ring and replace as necessary.
Installing plugs - 5.7L and 6.1L engines
Special care should be taken when installing spark plugs into the cylinder head spark plug wells. Be sure the plugs do not drop into the plug wells as electrodes can be damaged.
1. Start the spark plug into cylinder head by hand to avoid cross threading aluminum threads. To aid in installation, attach a piece of rubber hose, or an old spark plug boot to spark plug.
2. The 5.7L and 6.1L engines are equipped with torque critical design spark plugs. Tighten spark plugs to 12-14 Ft. lbs. Do not exceed 15 ft. lbs. torque.
3. Install ignition coil(s) to necessary spark plugs.
4. Using compressed air, blow out any dirt or contaminants from around top of spark plug. Before installing spark plug cables to either the spark plugs or coils, or before installing a coil to a spark plug, apply dielectric grease to inside of boots.
5. Position ignition coil into cylinder head opening and push onto spark plug. Twist coil into position.
6. Install 2 coil mounting bolts.
7. Connect electrical connector to coil by snapping into position.
5.7L engine - coil parts and removal
Plug wires - 2005 model 5.7 engines
Spark plug cables on the 5.7L engine are paired on cylinders 1/6, 2/3, 4/7 and 5/8. Before removing or disconnecting any spark plug cables, note their original position . Remove cables one-at-a-time. To prevent ignition crossfire, spark plug cables MUST be placed in cable tray (routing loom) into their original position. The cable retention clips (6) and (8) must also be securly locked. If cable tray removal is necessary, release the 4 tray-to-manifold retention clips.
1 - #8 COIL-TO- #5 SPARK PLUG (MARKED 5/8) 7 - CABLE TRAY
2 - #7 COIL-TO- #4 SPARK PLUG (MARKED 4/7) 8 - CLIPS (SPARK PLUG CABLE-TO-TRAY- RETENTION)
3 - #5 COIL-TO- #8 SPARK PLUG (MARKED 5/8) 9 - #2 COIL-TO- #3 SPARK PLUG (MARKED 2/3)
4 - #3 COIL-TO- #2 SPARK PLUG (MARKED 2/3) 10 - #4 COIL-TO- #7 SPARK PLUG (MARKED 4/7)
5 - #1 COIL-TO- #6 SPARK PLUG (MARKED 1/6) 11 - #6 COIL-TO- #1 SPARK PLUG (MARKED 1/6)
6 - CLIPS (TRAY-TO-MANIFOLD RETENTION)
NewJeepOverland is offline
How to Change Spark plugs on A 05 GC 4.7 with pictures sammy29926 WK Grand Cherokee & XK Commander Forum 31 03-18-2012 10:17 PM
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 07:17 PM
Change spark plugs on a 4.7 @ 30k? cpdorroh WK Grand Cherokee & XK Commander Forum 18 05-24-2009 07:26 PM
Help - Oil on Spark Plugs - 4.7L cmorra68 ZJ Grand Cherokee Forum 16 05-03-2009 05:13 PM
4.7 HO spark plugs change rparker559 ZJ Grand Cherokee Forum 5 09-21-2005 05:27 PM
