How to Change Spark plugs on A 05 GC 4.7 with pictures - Page 2 - JeepForum.com
 1Likes
post #16 of 32 Old 07-27-2010, 07:05 AM
Nightcrawler
2010 WK
My 1989 Nissan Pick Up 2.4 4 cyl had intake/exhaust plugs. Even at 350,000 kms, it went in for an e-test and the mechanic was shocked at how low the emissions were.
Great powertrain, but a shame about the rampant rusting on the body.
~ 2005 Jeep Grand Cherokee Limited 5.7 V8 with 5 spd Auto and Quadra-Drive II full-time Active 4WD ~
Nightcrawler is offline
post #17 of 32 Old 10-10-2010, 04:07 PM
dawgfan77
Awsome write-up! I have to do my wife's 08 next week. The manual recommends changing the "top row" at 30K miles, she has about 37K. Why would you only need to change half of them? Should I go ahead and do all 16 or just the top rows as recommended? When I asked a jeep tech about it, he said it was only a way to get the jeep in twice for the same service... 8 plugs now, and 8 plugs later.
Also, what plugs would you recommend for her 08?
dawgfan77 is offline
post #18 of 32 Old 10-30-2011, 08:26 PM
0321Nick
2006 WK
Old Thread, but wanted to send some thanks your way.
Just changed my spark plugs out today and it was a breeze because of the step by step I could study before starting.
I didn't even need to refer back to this Thread because your writeup was very well done.
Definitely was glad I picked up 1) a adjustable neck socket wrench (3/8") and 2) a multi-angle 5/8" spark plug socket. Came in handy during the passenger side rear plug!
Here's a question though - As I was changing the passenger side plugs (in the back) I found a male end of a electrical cord.... No idea what is was for or connected to... Does my used Jeep have a engine warmer hooked up that I wasn't told about?
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline
post #19 of 32 Old 10-30-2011, 11:33 PM
PeterF
2006 WK
Is that the chord that plugs into the temperature sensor on the air box?
PeterF is offline
post #20 of 32 Old 10-31-2011, 08:56 AM
0321Nick
2006 WK
I'm not sure, would it look like a straight-up-electrical plug?
On the bright side, with the new sparks my Jeep idles at about 650-700 rpm.
Before it was at 500 rpm and would flutter every once in a while.
KHAKI CLUB #65
0321Nick is offline
post #21 of 32 Old 10-31-2011, 08:18 PM
WJWKXJZJ
Block heater is 600 Watts and if you trace the cord, you'll find it leads to a freeze plug next to the starter.
Plug it into a timer and have warm coolant (100-120 degrees in 20-30 F weather if parking outside) without starting the engine and letting it idle before you set off on cold mornings. 1-2 hours should be enough plug-in time if you want to use it as I described.
WJWKXJZJ is online now
post #22 of 32 Old 10-31-2011, 10:50 PM
The_War_Wagon
2007 XK Commander
Originally Posted by sammy29926 View Post
Jeep has a coil over spark ignition system which means every spark plug gets its ignition coil. First Disconnect the coil plug and then loosen the 10mm coil holding bolt.
WORTH the price of admission!!! NOW I know why I can't find a plug wire SET for my 287 Commander!!!
'07 Commander, Rocky Mountain Edition, 67k miles, & looking for advice!!!
The_War_Wagon is offline
post #23 of 32 Old 10-31-2011, 10:58 PM
pjkatz04
This is what you see when you lift the hood.
after the new plugs are in, this is what you'll see when you close the hood.
2002 4.7, Selec-Trac, K&N FIPK II, JetChip Stage 1.
pjkatz04 is offline
post #24 of 32 Old 10-31-2011, 11:14 PM
0321Nick
2006 WK
Thats not what my 4.7L looked like after new plugs...
KHAKI CLUB #65
0321Nick is offline
post #25 of 32 Old 11-01-2011, 05:48 AM
pjkatz04
Haha great writeup!
pjkatz04 is offline
post #26 of 32 Old 11-01-2011, 08:55 AM
PeterF
2006 WK
0321nick I'll take a pic when I get home if you need it
PeterF is offline
post #27 of 32 Old 11-01-2011, 08:56 AM
BonesWK
2006 WK
there is a video in the FAQ section as well fellas!
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #28 of 32 Old 11-01-2011, 10:37 AM
0321Nick
2006 WK
Yeah, that would be sweet so I can be 100% positive. I'm pretty sure your right though.
Yeah, it's a good video - Really glad I caught his tip about having an angle adjustable socket wrench - very handy!
KHAKI CLUB #65
0321Nick is offline
post #29 of 32 Old 11-01-2011, 07:44 PM
PeterF
2006 WK
Here the temperature sensor chord.
Here it is plugged in.
Here is the sensor itself (taken out of the air box)
PeterF is offline
post #30 of 32 Old 11-02-2011, 09:39 AM
BonesWK
2006 WK
amen, that thing saved me big time when I did mine.
Ryan
BonesWK is offline
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 07:17 PM
Change spark plugs on a 4.7 @ 30k? cpdorroh WK Grand Cherokee & XK Commander Forum 18 05-24-2009 07:26 PM
How to change spark plugs on 5.7l ? daaaaaan WK Grand Cherokee & XK Commander Forum 1 04-19-2009 06:25 PM
Spark Plugs skisprinkle686 ZJ Grand Cherokee Forum 2 05-17-2006 12:31 AM
4.7 HO spark plugs change rparker559 ZJ Grand Cherokee Forum 5 09-21-2005 05:27 PM
