How to change front washer nozzles? - JeepForum.com
post #1 of 13 Old 02-14-2012, 10:27 PM Thread Starter
FredG713
2007 WK
I've been trying to pull the push plugs out so I can try and change the washers but they're almost impossible to pull out. Does anyone know how to get them out? I was only able to get one out and I ripped some of the insulation in the process.
Also I took the plastic mold off the dash and saw what looked like an aftermarket alarm system. I'll get a picture up tomorrow when the sun is out but is there supposed to be any type of box just above the speedometer that flashes green and red?
Last thing, I'm trying to change the rear wiper blade and can't seem to figure it out. I've already bought the replacement blade from the dealership (yes I know) but I didn't know where else to get it.
FredG713 is offline
post #2 of 13 Old 02-14-2012, 10:37 PM
colinzj
2006 WK
No blinkybox from the factory.
The rear wiper blade's incredibly easy once you know how. If you look at your new one, you should see two tabs. If you squeeze those together, it comes right off. The replacement pops right in. It's a little easier to swap out if you unpark the wiper first (gently lift the blade portion of the arm up and out to clear the parking stop under the glass), but you can do it as-is.
Dealer's the only place to get the rear blade (AFAIK) and the price shouldn't have been too bad.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #3 of 13 Old 02-14-2012, 10:40 PM Thread Starter
FredG713
2007 WK
Yeah it wasn't too bad, but my total came out to 8x.xx since I got the push tabs for under the hood, and the replacement spray nozzles.
Yeah I was going to pull it to clear the parking stop but didn't want to chance it. lol
Now if only I can get these tabs out and replace the spray nozzles. smh, always something.
FredG713 is offline
post #4 of 13 Old 02-15-2012, 07:14 AM
TurboDiesel
2008 WK
i work construction and i used my nail bar to take out the plugs under the hood
might try using some sort of pry bar like that
how much were the new nozzles?
i need 2 and my dealer quoted me 20 each...
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #5 of 13 Old 02-15-2012, 10:32 AM Thread Starter
FredG713
2007 WK
Yeah it was around 16-17 somewhere in there and the plastic plugs came out to 3x.xx for 9 smh.
FredG713 is offline
post #6 of 13 Old 02-19-2012, 10:49 PM Thread Starter
FredG713
2007 WK
anyone know how to change the nozzles?
FredG713 is offline
post #7 of 13 Old 02-19-2012, 10:54 PM
TurboDiesel
2008 WK
They should just pop in
I haven't changed them on my jeep
But I did them on my gfs 95 golf and yea, they just popped in and out
Just be careful with the new ones!!!
post #8 of 13 Old 02-19-2012, 11:03 PM Thread Starter
FredG713
2007 WK
I was told you have to go under the hood and take the liner out.
FredG713 is offline
post #9 of 13 Old 02-19-2012, 11:56 PM
TurboDiesel
2008 WK
Yep
post #10 of 13 Old 02-20-2012, 03:15 AM Thread Starter
FredG713
2007 WK
Ok, well I tried it and the damn plugs or damn near impossible to pull out and I used some vice grips...smh, any advice?
FredG713 is offline
post #11 of 13 Old 02-20-2012, 05:29 AM
LJS8510
LJS8510's Avatar
2015 WK
Sorry can't help in how to remove them, never replaced them.
But here is a view of them and good price on them
http://www.justforjeeps.com/nozzle.html
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #12 of 13 Old 02-20-2012, 09:50 AM
colinzj
2006 WK
Do you have needle nose pliers? Looks like the easiest way. There are two springy arms at the top that won't clear the hood once it's installed:
Squeeze them together or break them off, your call.
colinzj is offline
post #13 of 13 Old 02-20-2012, 11:55 AM Thread Starter
FredG713
2007 WK
Lol no i'm not that far yet. I'm trying to get the under hood insulation push plugs out. The plugs that hold the insulation in.
FredG713 is offline
Did my Front/Rear Diff. Gear Oil Change and TC Change Too torchd ZJ Grand Cherokee Forum 2 03-18-2010 09:51 AM
Who has actually changed their front windshield washer pump? figgity_diggity ZJ Grand Cherokee Forum 0 10-11-2009 07:18 PM
'02 GC Ltd. washer pump ?: are the front and rear both the same? figgity_diggity ZJ Grand Cherokee Forum 2 09-27-2009 09:44 PM
99 WJ needs new washer nozzles! Spydernut ZJ Grand Cherokee Forum 10 12-13-2008 04:53 PM
