How To Change Front Struts and Rear shock on a 05 Jeep Grand Cherokee Limited 4.7 - JeepForum.com
 3Likes
post #1 of 128 Old 07-20-2010, 09:35 PM Thread Starter
sammy29926
Hi Everybody,
On passenger side struts was leakig on ym wifes jeep and whole jeep felt like it was bouncing to much over bumps ect. It has close to 70K miles on it and we decided to replace the front struts and shocks on it. After getting couple of quotes from local shops I decided to tackle it myself and take pictures of it and hopefully this will be good guide for the DIY jeep owners. Whole job took me about 5 hours rears and fronts with home tools. Floor jack, 2 jack stands, 1/2 inch 18 inch long breaker bar and good set of sockets, wrenches. I would like to thank wookie for his contribution to give me the confidence to tackle this job. Following is a link to his thread;
http://www.jeepforum.com/forum/f67/f...myself-922863/
First I moved the coolant reservoir tank around to reach the strut mounting bolts.
http://i111.photobucket.com/albums/n...strut001-1.jpg
http://i111.photobucket.com/albums/n...strut002-2.jpg
http://i111.photobucket.com/albums/n...epstrut004.jpg
Here is the passenger strut mount bolts. They are 18mm and you need a deep socket. Please loosen them while the front tires are still on the ground. I have not jacked the jeep up yet..
http://i111.photobucket.com/albums/n...strut003-3.jpg
Move to the drivers side and you need loosent he 3 bolts holding the fuse/relay box on.
http://i111.photobucket.com/albums/n...strut005-5.jpg
http://i111.photobucket.com/albums/n...strut006-6.jpg
http://i111.photobucket.com/albums/n...strut007-7.jpg
Then you reach the drivers side strunt mount bolts. loosen them but do not take them off.
http://i111.photobucket.com/albums/n...strut008-8.jpg
After you are done with all the stuff above, lift the front end of the jeep and place jack stands unerneath it so both tires will be off the ground. ( Do not forget to loosen the lug nut bolts while the front tires are on the ground.) Take the tires off and and loosen the upper control arm ball joint bolt. It is a 18mm deep socket. After loosen it do not take it off all the way.
http://i111.photobucket.com/albums/n...strut009-9.jpg
loosen the lower strut clevis (fork) at lower control arm , the clevis bracket bolt. Loosen and remove swaybar bolt at the lower control arm.
http://i111.photobucket.com/albums/n...trut010-10.jpg
move the front ABS sensor wire away.
http://i111.photobucket.com/albums/n...trut011-11.jpg
Seperate the upper control arm ball joint fron the spindle.
http://i111.photobucket.com/albums/n...epstrut015.jpg
Remove the lower strut clevis (fork) at lower control arm.
Remove the 4 strut mount bolts.
Make sure you have a rope or bungee cord ready to secure the spinle to the upper control arm.
http://i111.photobucket.com/albums/n...epstrut012.jpg
http://i111.photobucket.com/albums/n...epstrut013.jpg
Strut assembly will come out between the brake line and the lower control arm.
Loosen the upper shock nut then using spring compressor tool compress the strut spring and then remove the upper shock mount. Slide everything out of the old strut assembly and put it all back together in th esame order they come out. the rest is vice versa...
Rear shocks are there by 2 bolts.. I believe they are 17mm. Loosen them and take th eold shock out , slide the new one in and tighten the bolts.. Rears are very easy to do..
Hopefully this gives you some kinda visual idea how everything looks ect. Give yourself about 5 hours with taking breaks ect. Shops around my area quoted me $450 for replace front struts. I was very happt to replace all the struts and shocks on my wifes jeep for about $250 in parts.. It felt good...
If you have anything to add like torque specs ect. please do so...
Have a great day.
Sammy
sammy29926 is offline
post #2 of 128 Old 07-20-2010, 09:40 PM Thread Starter
sammy29926
Could somebody make the images viewable instead you have to click on them.
I do not have the required 25 posts yet...
Sammy
post #3 of 128 Old 07-20-2010, 09:46 PM Thread Starter
sammy29926
I got the pictures to show up..
post #4 of 128 Old 07-20-2010, 10:00 PM
robpp
TORQUE FRONT
DESCRIPTION
Nm
Ft. Lbs.
Shock Absorber Upper Nuts
95
70
Shock Absorber Clevis Bracket
122
90
Shock upper Mounting Nut
39
25
Clevis Bracket to Lower Control Arm
169
125
Upper Control Arm Bolt/Nut to Body
108
80
Lower Control Arm Bolt
Rear Pivot
88
65
Lower Control Arm Bolt/Nut
Front Pivot
169
125
Upper Ball Joint Nut
95
70
Lower Ball Joint Nut
95
70
Stabilizer Bar Retainer Bolts
129
95
Stabilizer Bar Link Upper Nut
108
80
Stabilizer Bar Link Lower Bolt
115
85
Hub Bearing Knuckle Bolts
115
85
TORQUE REAR
DESCRIPTION
Nm
Ft. Lbs.
Shock Absorber Upper Bolt/Nut
95
70
Shock Absorber Lower Bolt/Nut
115
85
Suspension Arms Lower Axle Bracket Nut
210
155
Suspension Arms Lower Frame Bracket Nut
176
130
Suspension Arms Upper Axle Bracket Nut
136
100
Suspension Arms Upper Frame Bracket Nut
129
95
Track Bar to Axle
190
140
Track Bar to Rear Structure
190
140
42
31
Stabilizer Link Nut to Stabilizer Bar
88
65
Stabilizer Link to Body Bolt
102
75
Stabilizer Link to Bracket Bolt SRT8
102
75
Stabilizer Link Bracket Bolt/Nut To Frame SRT8
129
95
Jounce Bumper Bolt to Body
54
40
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #5 of 128 Old 07-20-2010, 10:17 PM
theSovereign
2007 WK
Detailed writeup, very nice!
Torque specs (as well as many more in-depth suspension-related details) can be found in this document: Jeep WK Grand Cherokee - Section 02 Suspension.
See pages 2-7 for Front and 2-49 for Rear torque charts.
I tried attaching the PDF of that doc, but JF gives an "Invalid File" error when I try to upload it.
theSovereign is offline
post #6 of 128 Old 07-20-2010, 10:18 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Awesome write up man, I'm adding it to the FAQ section.
Thanks for taking the time and effort to do this, it's greatly appreciated.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #7 of 128 Old 07-21-2010, 07:43 AM
Trice
1978 CJ5
How did you remove the lower strut bolt in the control arm? Last weekend tried to remove struts but got to that bolt and it would not move. It apparently is tapered and pressed in. Stopped because we were not getting it out and did not want to break anything by beating it out. The bolt is in picture just below where it says loosen sway bar bolt on lower control arm.
Trice is offline
post #8 of 128 Old 07-21-2010, 11:25 PM Thread Starter
sammy29926
Hi Trice,
I loosened the nut which is a non-metric size.. either a 1 inch or 1 1/16 in size.. I used my breaker bar and loosened the nut.. Bolt head on the other side will turn and it will hit a stopper..
Sammy
post #9 of 128 Old 07-22-2010, 07:08 AM
Trice
1978 CJ5
Tried that, it did not happen as easy as it sounds it did for you. The bolt would not budge. We are getting a impact wrench and going to give it a go that way. It seems as though the bolt it tapered... Is it tapered?
Trice is offline
post #10 of 128 Old 07-24-2010, 07:29 PM Thread Starter
sammy29926
Trice,
To be honest with you, everything went too smooth for my liking.. I was definetly expecting somekinda problem ect. I hope impact wrench would fix your problem with that particular bolt.. then there is the old cheater thrick.. you can slide a 4ft long steel pipe on a 1/2inch wrench and apply some pressure on that bolt..
good luck
Sammy
post #11 of 128 Old 07-26-2010, 07:41 AM
Trice
1978 CJ5
Got it done, and it looks great, hopefully tires today. The impact saved us, on the bolts and we actually went to a local shop and used the wall compressor to put the struts back together. Money well spent on that front. Apparently from what I hear those springs can kill ya and I don't know much about dead.
Trice is offline
post #12 of 128 Old 08-30-2010, 08:09 PM
TBabbitt
How to
I am trying to remove the lower fork/ A-arm bolt and i have removed the strut, fork bolt and the nut on the assembly itself but i cant Loosen and remove swaybar bolt at the lower control arm.
How did you get it out?
TBabbitt is offline
post #13 of 128 Old 08-30-2010, 11:11 PM
ThirstyLizard
2007 WK
Thank you!! Installing Bilsteins in front as soon as the come in the mail. I'm guessing an alignment is needed once finished?
ThirstyLizard is offline
post #14 of 128 Old 11-17-2011, 10:25 PM
JeepVanMan
2006 WK
thanks for the "how to"! I was able to do mine following your outline! Saved me 300$! i know i know and all you get is a thanks! I did a little slice and dice to the hands, tough work space and tight bolts!
JeepVanMan is offline
post #15 of 128 Old 11-29-2011, 09:14 PM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
Great How-to, wish I'd found it before I did mine. Unfortunately I tried removing the clevis/fork at the bottom when I could have pulled the strut out of the fork instead.
YB Normyl is offline
bilstein , bushing , clevis , seized
1995 Grand Cherokee Limited, Front Drive Shaft Q Birdee ZJ Grand Cherokee Forum 7 11-30-2013 05:48 PM
1998 Jeep grand Cherokee limited rear differential guy23ohio06 ZJ Grand Cherokee Forum 31 01-27-2013 11:16 PM
Struts on '05 Grand Cherokee aar1 WK Grand Cherokee & XK Commander Forum 1 06-01-2010 02:05 PM
Shocks and Struts for 06 Grand Cherokee Booch WK Grand Cherokee & XK Commander Forum 5 05-12-2010 12:20 PM
How to change front struts on a 95 Grand Cherokee SWADE23 ZJ Grand Cherokee Forum 6 03-27-2009 09:51 AM
