--HOW TO--add 2008 HID headlights to your 05-07 WK! - JeepForum.com
post #1 of 85 Old 08-16-2008, 01:27 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
05-07 headlight on the left and a 2008 HID headlight on the right--
First you need to remove your grille...2nd remove the 3 screws holding the 05-07 headlight...there are 3 abd they are 10mm. The one on the top is easy...the two underneath are difficult and require patience....especially the one near the grille.
back of the 08 light-
back of 08 light with the HID dust cover removed-
here shows how i trimmed the tabs of the xenondepot bulb to fit in the 08 housing. I added a couple drop of adhesive to hold it in good.
9006 bulb in 08 hid housing
Scottina06 is offline
post #2 of 85 Old 08-16-2008, 01:28 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
Next I pulled the casing off the d1s bulb that comes with the 08 hid's and used it to cover the 9006 bulb and to help secure it in the 08 housing-
bulb and cover from d1s installed in hid housing
dust cover installed-
lamp installed with no stillen cover-
post #3 of 85 Old 08-16-2008, 01:29 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
you will reuse the marker light assembly, turn signal bulb and assembly and the 9005 highbeam bulb and assembly from the 05-07.
post #4 of 85 Old 08-16-2008, 01:33 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
I decided to leave the Stillen covers off until I can get my shop to modify them slight. Lowered on Eibachs with 08 HID headlamps-
post #5 of 85 Old 08-16-2008, 02:29 PM
--chris--
--chris--'s Avatar
Looks nice! I did not even realize they changed the lights in 08?
--chris-- is offline
post #6 of 85 Old 08-17-2008, 10:37 PM
bobholthaus
2007 WK
So, what did it cost to buy the '08 assembly? You lost me up on using the xenondepot bulbs... did the '08 assembly come with the '08 HID bulbs? It looks like you used the housing from the '08 bulbs but aren't the d1s bulbs HID?
Thanks for posting all of this... I need this upgrade. Also, what are the "stillen covers"?
'14 GC Overland Diesel
bobholthaus is offline
post #7 of 85 Old 08-18-2008, 09:37 AM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
I paid $640 for the 08 lamps from LKQ. The 08 assembly did come with d1s bulbs and the ballasts. You can see the ballast on the bottom of the lamp. I didnt use the d1s and oem ballast because I wasnt sure what to do. I now know that I can use the d1s bulbs and ballasts. I just need to wire striaght to the ballast using my xenondepot relay harnesses. Then I can take out the xenondepot 9006 bulbs.
The Stillen covers are headlight covers made for the 05-07 WK's by Stillen Motorsports in CA. You can contact Jade at Stillen to purchase them. They are very similar to my ronconcept covers. Here is a pic of the passenger side with a Stillen cover....
post #8 of 85 Old 08-18-2008, 09:38 AM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
see....no gap now------
post #9 of 85 Old 08-18-2008, 09:40 AM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
post #10 of 85 Old 08-18-2008, 09:44 AM
bobholthaus
2007 WK
Thanks for the thorough update. Very nice. Thank you for taking the time to post it all and update us all on pricing. We appreciate it.
post #11 of 85 Old 08-18-2008, 01:54 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
Not a problem. I will be using the 08 d1s bulbs and ballasts as soon as a new d1s bulb arrives.(one was broken)
post #12 of 85 Old 08-18-2008, 10:05 PM
bobholthaus
2007 WK
Okay, trying to find LKQ to order a set of these. Where do I find these guys?
post #13 of 85 Old 08-18-2008, 10:24 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
www.car-parts.com I did a search of yards nationwide.....but unless its changed since last week...I got the only HID set listed.
post #14 of 85 Old 08-19-2008, 09:20 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
Just finished what I should have done in the first place. I used the 08 stock D1S bulbs and ballasts in my 08 headlight assembly retrofit. Believe it or not...if you buy the 08 assemblies and they come with the bulbs...all you need to make them work in a 05-07 WK....is a HID relay harness!(you can get them for $19.95 fron dxhid.com) I also used liquid tape(awesome stuff), electrical tape, heat shrink sleeves and plastic ties.
I have many pics below...so if you have any questions...please include the pic #. But...this is very, very easy.....and if I can do it...anyone can.
#1-this is the back of the 08 drivers lamp. The power and ground for the ballast is circled in red with the arrow pointing...
#2-tools and supplies needed
#3-d1s bulb plugged in
#4-d1s bulb installed-
#5-on the passenger side lamp...there are 8-10 wires going into the lamp. Just pull the rubber stopper out and trace the wires going to the ballast. On my lamp...they happened to be black(ground) and dark grey(power). the drivers side just has two wires going into the rubber stopper...they are also grey and black.
#6-In these pics....I stripped the wires and connected the relay harness to the lamp. On my harness I had to cut the plug off that went to the HID bulb(9006 kit) and then I wired the green to the power and the black to the ground...which then I connected to the fender grounding location. I used the liquid tape on the open wires and then the heat shrink tape on top of that. I then plugged the relay harness into the 9006 plug from the truck harness and routed the relay harness to the positive on the battery. the drivers side is the same procedure.
#7-The results----
post #15 of 85 Old 08-19-2008, 09:21 PM Thread Starter
Scottina06
Scottina06's Avatar
2006 WK
#8-d1s hid's and Silverstar ultra 9005 fogs
#9-My stock d1s bulbs and my wifes 2008 Lexus IS with D4S 6500K bulbs
2008 Overlander headlights aim low all the time wilsonb1 WK Grand Cherokee & XK Commander Forum 2 07-30-2009 05:53 AM
2008 Key FOB acsimon WK Grand Cherokee & XK Commander Forum 2 11-27-2008 10:59 PM
2008 HID Headlights vs. Standard. Worth it? gsxr150 WK Grand Cherokee & XK Commander Forum 14 05-19-2008 07:27 AM
Grand Slam West 2008 Scheduled - May 30-June 1, 2008 FPKites ZJ Grand Cherokee Forum 54 05-15-2008 10:40 AM
2008 Limited/Overland headlights S10Eater WK Grand Cherokee & XK Commander Forum 3 01-22-2008 08:11 PM
