Hood wont close. Need help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Hood wont close. Need help
Jeep Long Arm Upgrade Kits on SALE for as low as $649.95 SKOR Name Your Price SaleThe Original 3/8" Ruffstuff Diff Cover!
Unread 01-31-2013, 06:47 PM   #1
JordanD07
2007 WK
Went to change my headlight out today and after I finished I went to close the hood and it won't close all the way. It will latch but won't go all the way down to lock. Anyone know how to fix this?
'07 3.7 4x4 QT1 ll Red WK Club #27 ll OME ll Monroe LL ll Rusty's ll ProComp ll BFG ll 4xGuard ll S4XC ll VLEDS ll Infinity ll Thrush ll Riddler ll 6K HID
JordanD07 is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 07:02 PM   #2
JordanD07
2007 WK
Also could someone take a picture of their hood latch when the hood is open so I can compare it with my latch? Thanks
Unread 01-31-2013, 08:25 PM   #3
silentj
2006 XK Commander
Make sure the release lever under the dash is back to the normal position. Mine gets stuck sometimes and I have to push back into the normal position. Should close after that. Good luck.
06' XK 3.7 - RC 2" Lift | Hypertech Max Energy 52001 | Bilstein HD Front & Rear Shocks | Hankook DynaPro ATM 255/70R18 | 18" Sahara wheels | Spidertrax 1.5" Spacers | Rola Basket | Smittybilt D-ring Tow Hitch | 4XGuard Matrix | Hella 500's
silentj is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 08:33 PM   #4
JordanD07
2007 WK
It's back in the original position. I think that the cable might have come loose but I'm not surr
Unread 02-02-2013, 05:10 PM   #5
JordanD07
2007 WK
Bump
Unread 02-02-2013, 05:45 PM   #6
xXDiligenceXx
2005 WK
So once it latches, it won't move down any further to catch? Like that is the end of any downward movement.
Or does it latch and you can push it down but it will not catch to completely shut?
xXDiligenceXx is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 01:07 AM   #7
Minjarez
Newbie
Minjarez's Avatar
2005 WK
Just ran into this issue on my 05 WK 5.7L. I found that the locking piece got stuck and needed to be tapped with a screwdriver. That let the arm swing back out to catch the hood latch when it was closed. Don't know if it helped being a year late haha but perhaps it will help someone later on.
Minjarez is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 10:55 AM   #8
DRWonoski
2005 WK
mine does that all the time but so far 100% of the time its from me leaving a screwdriver or wrench somewhere I shouldn't
DRWonoski is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 03:40 PM   #9
2000vikings
2010 KK Liberty
Be careful with this, just this past weekend going 65mph on an interstate highway, I had my hood on my 1996 Grand Cherokee Limited open and flip/bent over my windshield. It was one of the scariest moments of my life. I got off the highway safely, but needed to replace the hood hinges and am still using the bent hood until I can get another one from the salvage yard.
2000vikings is offline   Reply With Quote Quick reply to this message
