Hill descent assist when you don't have one ;) - JeepForum.com
post #1 of 16 Old 11-15-2007, 04:03 PM Thread Starter
menoche
menoche's Avatar
2007 WK
Hi guys,
on my last navigation rallye, I did an interesting discovery....
In a portion of the route, we had to drive at 22km/h... so I used the cruise control to make sure I was right on with GPS verification.
to my surprise, I noticed the transmission would shift down to slow the Jeep down and at one point, it even put the brakes on?!??!!?
I might not be a "real" descent assist but it sure does the job.. ok ok you're saying what about 1-4 km/h when going down, I don't know.. I haven't tried it so low yet... I'll do a bit of testing and come back with results.
Phil
menoche is offline
post #2 of 16 Old 11-16-2007, 12:24 AM
merlinTec
merlinTec's Avatar
Hi
It’s unlikely it put the brakes on
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 16 Old 11-16-2007, 07:21 AM Thread Starter
menoche
menoche's Avatar
2007 WK
yeah that's what I thought too... but i really felt it braking.. was it just ESP kicking in because I was on a gravel road.. not too sure.... I'll have to re-explorer this issue at low speeds...
how low is the cruise control supposed to kick in? on my subaru below 30km/h it turns off...
Phil
menoche is offline
post #4 of 16 Old 11-16-2007, 12:09 PM
CEPCNC
2005 WK
I believe our US WKs cut off below 30mph.
CEPCNC is offline
post #5 of 16 Old 11-16-2007, 12:31 PM Thread Starter
menoche
menoche's Avatar
2007 WK
well the canadian version still holds at 22kmph
menoche is offline
post #6 of 16 Old 11-16-2007, 02:32 PM
CEPCNC
2005 WK
I could be wrong...haven't tested CC that in depth...I'll try tonight
CEPCNC is offline
post #7 of 16 Old 11-16-2007, 03:11 PM
merlinTec
merlinTec's Avatar
Hi
All speed controls are set to work above 30mph (50 km/h) speed control can be set between 35mph (52.6 kph ) and 85mph (136.8 kph) menoche are you sure yours work that low? If so lucky you I am very surprised. Country codes I can’t see would make any difference as the PCM doesn’t always store the country code. Think our WH just say none US. Seen all sorts on KJ such as brazil and china and this can’t be changed.
Regards,
Merlin
post #8 of 16 Old 11-16-2007, 05:31 PM
WKTrailRunner
2007 WK
World wide, how many WK's are creeping down hills with the CC on right now? I'll go try after rush hour.
WKTrailRunner is offline
post #9 of 16 Old 11-16-2007, 08:27 PM
AferVentus
With our '08 CRD Overland, we can set it as low as 14 mph. We have tried this, because the manual said it will work at this low of a speed. All the other engines don't let you engage it until upwards of 35 mph.
AferVentus is offline
post #10 of 16 Old 11-16-2007, 10:14 PM
bull_blaster
2005 WK
on my 05 WK i set the speed @ 25 whenever iam going through a school zone and it hold just fine.
bull_blaster is offline
post #11 of 16 Old 11-16-2007, 10:50 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Hill descent, why not just shift into 1st and let the engine compression work for you? That is, if you are going that slowly.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 16 Old 11-16-2007, 11:12 PM Thread Starter
menoche
menoche's Avatar
2007 WK
ok i tried again with my 07 CRD and couldn't set it lower than 22kmph... under that cc wouldn't kick in at all, so kiss good bye my weird idea.
why not in first? Becase even in first gear in some steep slope, it will over rev.
I still have to try again the 22kmph on a steep sloap to find out why my esp kicked in last time to make sure it was juste because of the gravel....
menoche is offline
post #13 of 16 Old 11-17-2007, 02:07 PM
CEPCNC
2005 WK
X2 on this note
CEPCNC is offline
post #14 of 16 Old 11-17-2007, 03:09 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sir,
the engine will sound like it is going to overrev but, not really. Try shifting into 4.lo and 1st. No way to overrev the motor.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #15 of 16 Old 11-17-2007, 03:53 PM Thread Starter
menoche
menoche's Avatar
2007 WK
DUH!!! should've tought about the 4 low revving higher for gears in the first place!!!
Bonus points for Texas ZJ1!!!!
Thanks for the insightfulness
menoche is offline
06 WK park assist problem jm020 WK Grand Cherokee & XK Commander Forum 0 02-07-2010 09:12 AM
What is a descent winter tire? 69speed ZJ Grand Cherokee Forum 7 11-23-2007 09:28 AM
Do I Have Variable Assist? ALLJEEP95 ZJ Grand Cherokee Forum 3 07-10-2007 07:17 AM
hydraulic steering assist mudboggerrebel ZJ Grand Cherokee Forum 1 12-30-2006 05:19 PM
Rear Parking Assist HELP hshlevin ZJ Grand Cherokee Forum 6 06-25-2006 09:35 PM
