Is this hill decent working? - JeepForum.com
post #1 of 5 Old 07-30-2007, 03:56 PM Thread Starter
Dieseljoe
2006 WK
My Jeep is 06 Grand Cherokee with the 5.7 liter Hemi.With the cruise control on at 60 mph going down a slight hill on a expressway the tach will drop from 2K to 1500 then go back up then drop again.Is this hill decent control?The tranny is in overdrive.Thanks Joe
Dieseljoe is offline
post #2 of 5 Old 07-30-2007, 08:23 PM
zim
WOW
'08 JK Sahara 4 door
'06 XK Limted Loaded
'90 YJ SOA, 35" MTR's, Ford 8.8, 4.56 gears, 355 sb, Warn sliders, skids, bumber/carrier Sold :(
zim is offline
post #3 of 5 Old 07-31-2007, 04:42 AM
HurriJeff
2013 WK
Whats probably happening is that when you go up the hill the cruise adds throttle to maintain speed and when you start to go down hill the cruise releases the throttle and your engine speed drops. Modern transmissions tend to unlock electronically based on engine load in order to save fuel. That could be a contributing factor in the drop in engine speed as well. I'm sure its nothing to worry about.
I'll test mine at 60 for you just to see if mine dose it as well.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #4 of 5 Old 07-31-2007, 09:16 AM
zjkid
no hill decent on that year.
zjkid is offline
post #5 of 5 Old 07-31-2007, 11:24 AM
2007GC Overland
2007 WK
Hi Folks
My 07 has it and it will drop the from 5 gear to 4th to maintain the speed I set it at work great but sometimes, I guess I would rather coast but with cruise control that is not an option. You can expect the engine to jump around with crusie control - it add power and takes it away.
thanks
Bill
2007GC Overland is offline
Cruise not working/AC not working correctly: Need Vacuum line diagram JoshuaDHarp ZJ Grand Cherokee Forum 3 07-28-2011 05:20 PM
traversing a steep hill jmichaels WK Grand Cherokee & XK Commander Forum 5 01-05-2010 09:10 AM
Hill descent assist when you don't have one ;) menoche WK Grand Cherokee & XK Commander Forum 15 11-18-2007 12:55 AM
Is this a decent deal/decent tires? John in MA ZJ Grand Cherokee Forum 5 01-04-2007 02:19 PM
Up hill hesitation Arkansas_WJ ZJ Grand Cherokee Forum 3 02-07-2006 09:21 PM
