high voltage o2 sensor/bad coolant sensor - JeepForum.com
post #1 of 2 Old 01-24-2010, 10:36 AM Thread Starter
Jh24k
1998 WJ
I have a 98 grand cherokee 5.9. Recently my check engine light turned on. I had I checked. It said high voltage 02 sensor bank 1 sensor 1(been running choppy and flooding out or gas starved). So I decided to replace both since the truck has 200k on it. To my dismay it did not solve the problem(I did reset code). I also had bad coolant sensor reading on dash(changed and still did not remove error mess). Could the two issues have something to do with the other? Please help(would be greatly appreciated) before I decide to get medival on it.
sorry bout multiple post (new guy to any forum)
Jh24k is offline
post #2 of 2 Old 07-19-2013, 10:22 AM
diejeep
2008 WK
o2 sensors
hi did you unfasten your ground cable for about 10 mins after replacement?
diejeep is offline
hogh voltage 02 sensor/bad cool sensor Jh24k ZJ Grand Cherokee Forum 0 01-24-2010 10:33 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
Error P0122: Throttle Position Sensor Voltage Low. TimeOut ZJ Grand Cherokee Forum 4 11-06-2005 08:28 AM
low coolant sensor bigben9664 ZJ Grand Cherokee Forum 2 08-25-2004 03:10 PM
coolant sensor ? gerbort ZJ Grand Cherokee Forum 1 07-21-2004 02:20 PM
