hid lights? - JeepForum.com
post #1 of 18 Old 09-09-2013, 07:54 PM Thread Starter
wicat3
2005 WK
hid lights?
Hey guys I want to add HID lights to my 05 gc but wasn't sure if there was anything special I had to do? I have used a kit from ddm tunning before and wasn't sure if this type of kit would work for me? Any help would be great
wicat3 is offline
post #2 of 18 Old 09-09-2013, 08:47 PM
Shafer57
2006 WK
You will need a relay harness, or else they'll flicker.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #3 of 18 Old 09-10-2013, 03:59 PM Thread Starter
wicat3
2005 WK
But I belive I can make my own or buy one from ddm if im not mistaken
wicat3 is offline
post #4 of 18 Old 09-10-2013, 04:08 PM
Mainsail
2005 WK
Add HIDs....as in headlights or aux lights?
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #5 of 18 Old 09-10-2013, 04:49 PM
R32R1
2006 WK
NO. That is hack and looks like s*it. Leave the HIDs alone and buy a high-quality halogen bulb, instead of looking like a ****** blinding everyone.
R32R1 is offline
post #6 of 18 Old 09-10-2013, 05:27 PM Thread Starter
wicat3
2005 WK
Head lights. Halogen bulbs can make you look like an ******* too but if you do HIDs right you don't blind anyone
wicat3 is offline
post #7 of 18 Old 09-10-2013, 06:32 PM
R32R1
2006 WK
Yea an excessive amount. Good halogens in stock housings do not disturb others. HIDs only work in projector housings
R32R1 is offline
post #8 of 18 Old 09-10-2013, 06:42 PM Thread Starter
wicat3
2005 WK
so who makes good halogens and whats involved in installing them? just changing the bulb?
wicat3 is offline
post #9 of 18 Old 09-10-2013, 06:53 PM
Shafer57
2006 WK
HID bulbs/ballasts won't hurt anyone as long as you install them correctly.
Adjust your headlights making sure they're aimed down a bit if needed.
Sounds crazy, but I parked in the street at night, turned on my lights, and jumped in my GF's Mazda 3 and went down the street to see how they look oncoming. And I adjusted accordingly.
But for the record, you'll never get "great" results without having the proper housing, instead of focusing the light, these housings scatter/throw light. So unless you aim your headlights down a bit, they blind oncoming traffic.
Shafer57 is offline
post #10 of 18 Old 09-10-2013, 06:54 PM
imthehink
imthehink's Avatar
These are good:
http://www.amazon.com/Philips-9012-S.../dp/B00480N18G
They take a slight modification by cutting off a tab which will be obvious when you see it.
imthehink is offline
post #11 of 18 Old 09-10-2013, 07:00 PM
imthehink
imthehink's Avatar
Whats the point of getting HID when you have to aim down and lose what you are trying to achieve? Just do a retro and be done.
post #12 of 18 Old 09-10-2013, 07:10 PM Thread Starter
wicat3
2005 WK
whats the retro?
wicat3 is offline
post #13 of 18 Old 09-10-2013, 10:02 PM
Shafer57
2006 WK
By all means, using the correct housing is the best route.
HID bulbs as said before "Throw" light in all directions, including up. So by aiming the housing down a bit, it eliminates some of the light being "thrown" upwards.
I've read on this forum about bulbs called HIR's being pretty much the best bulb you can use in the stock housing.
Shafer57 is offline
post #14 of 18 Old 09-10-2013, 10:15 PM
Mainsail
2005 WK
I was driving to work early one morning when some yahoo with mis-aimed, self-installed HID bulbs in his Honda headlights came up the road ahead of me. I flashed my highbeams but I knew that wasn't it. Then I hit the switch on the two 450 watt 25 volt aircraft landing lights on the grille and I have no doubt he was seeing spots for hours, if he could see at all.
The moral of the story is: don't piss off the other drivers, they may well be able to do something about it.
Mainsail is offline
post #15 of 18 Old 09-10-2013, 10:32 PM
Shafer57
2006 WK
I think the worst is when they don't even invest in HID's, they buy the Blue tinted bulbs at local flea markets. How THEY can see is beyond me.
HID's unforunately come in many colors Blue>White(ish)>Purple. Higher the "K" the more purple they are. Most I see are either purple, or dark blue. Mine are as white as possible (I forget what K they are)
Shafer57 is offline
