Hemi hesitation - present in all or some? - Page 2 - JeepForum.com
post #16 of 38 Old 01-02-2008, 05:34 PM
RCHavok797
RCHavok797's Avatar
I've seen on other drive by wire cars that people are putting a ground wire to the throttle body for better response. My friend did this on his Mazda 3 with good results.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #17 of 38 Old 01-03-2008, 05:57 AM
HurriJeff
2013 WK
Yea... I kinda figure its a computer thing. Just kinda crappy, and funny too cause that fx45 thinks he's got you for that first 3 seconds then.. whammo.. see ya ! hehehe.
In all seriousness.. (snicker) its probably a good thing, in the big picture, its probably making a quiet difference in the WK overall safety rating, helping reduce certain types of accidents. Maybe people who inherently tap the pedal instead of easing it down. Probably benefits in snow and in low traction situations like boat ramp.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline
post #18 of 38 Old 01-03-2008, 11:29 AM
2007GC Overland
2007 WK
Hi Folks
My Hemi does not appear to have a hesitation problem - not that I can tell. It is my wife's jeep but on weekends I drive it. I looked to see if I could feel any hesitation this weekend or sense any - none. It responded to the push of the pedal. I normal drive a 6 speed Manual trany, V8 (LT1) Camaro - no hesitation there at all - so that is how I judge the Jeep.
thanks - just my 2 cents
Bill
2007GC Overland is offline
post #19 of 38 Old 01-03-2008, 02:19 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
Bill - I believe what we are talking about here is not a hesitation like there is no movement or a delayed response to the pedal push. It is more of a hesitation of the full power of the engine when you drop the hammer. I'm sure in your camaro as in any RWD vehicle I've driven, when you drop the hammer those rear wheels are screaming. In the WK that does not happen, it kind of gently eases up and then bam you feel it blast through the power band. It is deffinately a different experience.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #20 of 38 Old 01-04-2008, 04:50 AM
Onyx Dragon
1994 XJ Cherokee
It's just torque management. GM does it too with the supercharged Grand Prixs, only it's not as bad as what you guys are describing.
1995 Jeep Cherokee- 4.0 + 5 Speed
1987 Toyota Celica GT-S
Tomorrow's victory is won after today's practice.--Samurai Maxim
Onyx Dragon is offline
post #21 of 38 Old 01-04-2008, 06:57 AM
2007GC Overland
2007 WK
Hi Drewman141
I have put down the hammer on my Jeep - it responded quickly but I noticed as the RPMs build up the Jeep pulled harder. I contributed that to the cam and the tuning. My 02 Camaro SS (Modified) does not start pulling hard until it hits 3500 RPMs (Cam), after 3500 hang on to the seats because it pushes you back hard. The Jeep appears to do the same. I will try it this weekend.
thanks
Bill
post #22 of 38 Old 01-04-2008, 07:17 AM
anerbe
The hemi engine seems to develop more torque in the higher RPMs, but there is a slight delay in full power in the low revs. I assume it's to avoid sudden shock to the driveline, especially in low traction situations where the vehicle may send all power from 1st gear to one wheel with full traction.
this could potentially be damanging to the car.
02 M3 - Sold
06 WK Ltd 5.7
anerbe is offline
post #23 of 38 Old 01-07-2008, 12:38 PM
2007GC Overland
2007 WK
Hi Folks
Took the Hemi for a fun drive, turned off the traction control, and put the pedal to the metal - The Hemi has a power band ~2500 RPM to 5500 RPM, below that is pulling but not as hard as above 3000. This normal type performance profile I expected to see You might be able to tune the low end to pull harder but I have to believe the cam is setup for the power range above 2500 RPMs. You are pushing a 4700 vehicle, not include driver or passenger. I think it pulled pretty well for a vehicle its size.
Thanks
Bill
post #24 of 38 Old 01-07-2008, 09:15 PM
falcon10
I read in another forum sorry did not grab the link that many hemi owners figured out a way to recalibrate the throttle.
What you need to do is turn the key to on but do not start the car. when all chimes go away add pressure to the gas pedal til it is to the floor. Then release and turn key to off. Should at the next start raise rpms to 800 or so and heard that it will improve the hesitation some.
Many hemi owners seem to have done this and it has worked for the majority adding improvement.
Let me know how it goes
falcon10 is offline
post #25 of 38 Old 01-10-2008, 07:27 PM Thread Starter
JCDubya
2009 WK
What I experience is exactly that (the bolded portion ^). From a stop, you push the pedal then a second later you move. It's not a gradual build-up, it's an off-then-on sort of thing.
JCDubya is offline
post #26 of 38 Old 01-11-2008, 05:28 AM
HurriJeff
2013 WK
Yes JC.. I get that too. I used to have a big carburated engine in a street rod and I used to "hop speed bumps" by taping the accelerator at just the right time. By preloading the front suspension then hitting the gas I could get the car to hop over speed bumps but it required about three perfectly timed taps and the throttle response had to be right now. Of course the WK is not about that in any way shape or form, but the experience of doing that had made me aware of throttle response. This Hemi has plenty of that "Drive by wire" lag between pedal push and tachometer move. By compairison.
Previous Jeeps:
post #27 of 38 Old 01-11-2008, 06:58 AM
HurriJeff
2013 WK
Just dropped my kid off at school and I tested it. I can push the accelerator pedal all the way to the floor without feeling a surge if I do it quickly. It really does not compromise the driving satisfaction I get from my WK but it exists. There is a delay between pedal push and engine speed increase.
Previous Jeeps:
post #28 of 38 Old 01-11-2008, 07:51 PM Thread Starter
JCDubya
2009 WK
yeah, no doubt the HEMI is a fun Jeep to drive I just wish they could've addressed this issue as it would be a simple fix.
Once you drive it a for while you do get use to it but when i use my WJ THEN drive the WK I'm like, this sucks!
JCDubya is offline
post #29 of 38 Old 01-24-2008, 06:10 PM
fnckr
My 2005 had a re-flash from the dealer and the problem no longer exists.
To be sure, from a stop, my Hemi would not respond to the first 1/4 of smooth throttle input and then lurch forward seemingly making up for it's inattentiveness. It was very hard to accelerate authoratively and smoothly. I could be a granny or a punk but no where in between.
After the flash the acceleration and smoothness correspond naturally with the throttle input.
The flash is referred to in one of the TSBs. If I find it I'll post. It might be on the WKJeeps.com site.
fnckr is offline
post #30 of 38 Old 01-25-2008, 12:52 AM
AZCoronaDog
2014 WK
My 2008, purchased on 12/22/08 does not seem to have this issue.
My daily driver is a 2002 Camaro SS, so I do know what good acceleration is all about (13.3 @ 106 in the 1/4).
I read this thread awhile back, but I didn't want to post until I was sure I had thoroughly tested for this problem.
I tried light power braking as a comparison to just hammering it, and there was very little difference, so I'm satisfied that the Jeep accelerates just fine.
Update: I punched it off the line the other day and got a nice little chirp from the front tires (Quadra Drive II full time 4x4). I was able to repeat this at the next light too, so apparently the throttle delay can be fixed (at least on the '08).
AZCoronaDog is offline
Seriously...why 330 hp Jeep Hemi and 350hp Dodge and Chrysler Hemi??? HurriJeff WK Grand Cherokee & XK Commander Forum 11 09-23-2012 01:53 PM
5.7 Hemi vs 6.1 Hemi Plug Wires DougDunlap WK Grand Cherokee & XK Commander Forum 20 11-05-2011 11:50 AM
2009 hemi vs 2005-2008 hemi pauld WK Grand Cherokee & XK Commander Forum 11 01-29-2010 11:06 PM
Hesitation on acceleration - 5.7 Hemi geo1400 WK Grand Cherokee & XK Commander Forum 15 09-01-2009 02:36 PM
Christmas Present Jones ZJ Grand Cherokee Forum 18 12-08-2008 06:39 PM
