Help.... Transmission acting up. What is it? - JeepForum.com
post #1 of 8 Old 11-25-2016, 03:11 PM Thread Starter
shortysmash
2007 WK
So this morning I went a cranked up my jeep, put in reverse and all it did was high rev and slowly back out. I put it into drive and same thing. Three are no lights on the dash. It's not cold here and it was fine yesterday. Any ideas? The link below has a video of what's happening ( sorry for the video turning)
https://m.box.com/shared_item/https%...hz4nsae5ygc5ps
shortysmash is offline
post #2 of 8 Old 11-25-2016, 08:34 PM
durango-bob
2006 WK
Have you checked your fluid level?
durango-bob is offline
post #3 of 8 Old 11-26-2016, 08:39 AM Thread Starter
shortysmash
2007 WK
Yeah drain and fill a month ago.
post #4 of 8 Old 11-26-2016, 09:35 AM
suctoes
Did you use Mopar approved fluid? Also, has the trans filter been changed?
suctoes is offline
post #5 of 8 Old 11-26-2016, 10:00 AM Thread Starter
shortysmash
2007 WK
I dont know about the fluid, but the filter was changed. I also noticed when it's in drive I cannot switch to 1,2,3,4
post #6 of 8 Old 11-26-2016, 02:24 PM
acabtp
2005 WK
ok, but have you rechecked the fluid level since the problem started?
'05 WK Limited 5.7 Hemi
acabtp is offline
post #7 of 8 Old 11-26-2016, 03:19 PM
suctoes
If you let it idle in park for 10 min does the problem go away?
The first thing to check fluid level. Then try a simple battery disconnect for 5 minutes, then power it back up and try it again. See if any of these make a difference.
suctoes is offline
post #8 of 8 Old 11-27-2016, 09:31 AM
suctoes
Any updates?
suctoes is offline
