Help: Is there an aftermarket radio head unit... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Help: Is there an aftermarket radio head unit...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineYear End Clearance Sale! Save 20%Warn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 10-14-2014, 01:30 PM   #1
Marcus86GLHS
....that is a direct replacement for the factory 2008 WK double-DIN my gig touch screen radio head unit? one that does not require me to cut/modify the factory wiring or factory mounting are? one that allows me to retain the back-up camera feed and steering wheel controls?
there must be a thousand aftermarket units out there that can work but require modifying the wiring, or the mounting, or both.
help! (thanks)
2008 Grand Cherokee Limited 4X4, Light Greystone Pearlcoat, Hemi, Tow Group, 18" Chrome Clad Wheels. Original owner, 20,000 miles
2002 Wrangler Sahara, black, 4.0L, 5-speed, Dana 44 rear axle with Trac Loc LSD, duel tan tops, Canyon wheels with Wrangler Silent Armors. 75,000 miles, 2nd owner.
Marcus86GLHS is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 02:26 PM   #2
colinzj
2006 WK
If anyone's modifying the wiring, they're doing it horribly wrong; adapter harnesses have been commonplace since the late 80s and should always be used.
That aside, the long and the short of it is that no, you're not going to fit a Double DIN stereo without mounting or trim modifications because the MyGIG is not Double DIN.
The MyGIG units use an 8.125" x 3.75" opening. The DIN system is based on a roughly 7" width and a roughly 2" height; Double DIN is ~7" x ~4". Some aftermarket trim is available if you don't want to modify your factory trim, but obviously you can't neatly fit a 7x4 radio in an 8x3.75 hole without something being modified.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is online now   Reply With Quote Quick reply to this message
Unread 10-14-2014, 02:55 PM   #3
caddydaddy
2007 WK
Contact Crutchfield: http://www.crutchfield.com/ I just purchased a Jensen SatNav radio replacement for my '05 Escalade, and they told me what adapters I needed to get the steering wheel controls, XM and OnStar to work with the new unit. They should be able to help you out.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
168,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 03:11 PM   #4
Marcus86GLHS
^thanks I'll give them a try.
I just measured my original head unit, it is 3.73" tall and 8.00" wide, this the portion that projects thru the fascia (the opening in the fascia is slightly larger than those dimensions), so that isn't a true double DIN? That explains a lot, many of the descriptions I see for refurbished factory units describe the units as "double DIN", so that would be wrong?
Unread 10-15-2014, 09:44 AM   #5
Marcus86GLHS
ok now I have the full picture: when a radio is called double DIN they are referring to the CHASSIS size, not necessarily the face plate size.
the factory chassis is not true double din, it is 7 inches wide but only 3.25 thick, even though the face plate is true double din.
so the issue is that aftermarket double din chassis are too thick (the face plates are fine), when you install a 4" thick chassis in a WK it will go in about 3/4 the way in then hit the dash bracing, which would have to be cut.
out of luck, its back to the factory crap=o=la unit.
Unread 10-16-2014, 12:54 AM   #6
ggrassmid
Look at the RER's out of a Chrysler 200, those are supposed to be the low speed models and work with our WKs, then at least you get the updated maps and bluetooth streaming.
Also, just a wire harness in teh dash may not work. Do you have the factory amp? The head-unit and amp are designed to work together, the amp, I believe, will not work with an aftermarket head-unit.
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 02:20 AM   #7
Marcus86GLHS
the RER's are very pricey, at least the ones I found are, double the cost of what I have now.....yes my WK has the Boston acoustics system with the big amp and yes you are right many of the aftermarket wiring harnesses do not support all of the factory functions.
i've never had an issue with the factory unit's performance only its lousy reliability, my WK has just over 22,000 miles on it and I will be on my third head unit!
