(Help) Starting Problems? - JeepForum.com
post #1 of 2 Old 12-22-2013, 01:59 AM Thread Starter
Joeperl
2007
Grand Cherokee Limited 4x4
4.7 Engine
83,165 Km
Hi, I have a problem that has me totally frustrated , I tried with 3 workshops, all say the problem is the fuel pump (all three have changed) and continues with the same problem and each has changed something and still persists problem
The problem is that when the key step to turn my car is trying to turn on but never turned on, can be trying for minutes and nothing on, sometimes it happens and sometimes not , it happens randomly, sometimes when you turn is a very high odor gasoline , other times it seems to turn out not to be drowning and turns but sometimes is just trying to turn on and nothing .
I changed the fuel pump twice the fuel pump unit and the last time the complete fuel pump .
Chrysler scanner does not throw any codes on the problem
Battery is perfect and has the perfect voltage.
Injectors were checked and all good , the coils also , change the spark plugs, fuel filter was also changed to electrical level everything is in perfect condition.
The car goes on after switching rails , all perfect no fault or high speed or low, or detained . Only fails when off completely and indefinitely (usually over 10 min ) and randomly fails or
I discovered that when it fails, I go to the engine and fuel line where is the bug to measure the pressure of fuel, floor and let out a little gas (out with pressure) then I give the key and turns smoothly.
The last workshop said they are canister hoses .
The last workshop sent me to buy the following: in the attached photo ( could tell me the part number are indicated in red and black and they say 1 and 2 , since the shop did not know me ) .
I am totally frustrated with this problem , I think the problem is too much for the workshops here or are extremely idiots down here .
Thank you in advance for your wisdom and advice future. Sorry for my english
Joeperl is offline
post #2 of 2 Old 12-26-2013, 04:15 PM Thread Starter
Joeperl
bump help
Joeperl is offline
