Help removing screw - JeepForum.com
post #1 of 7 Old 04-17-2013, 07:06 PM Thread Starter
bmgrosso
2008 WK
Help removing screw
One of the screws holding rack on my roof wont come out. It just keep spinning when I try to unscrew it. I tried pulling on it with plyers but cant get a good enough grip on it. I also sprayed it with WD-40 which didnt do much. I cant tell if the threads are ruined or if the threads are just spinning with the screw kindve like a bolt would. The pictures below show what the threads from the other side look like and the screw thats stuck. Any ideas how to get it out? I think it might be in there too far to stick something under it and pry up while unscrewing if that makes sense...
2008 WK - 3.7L V6 - Magnaflow Exhaust
bmgrosso is offline
post #2 of 7 Old 04-17-2013, 08:11 PM
Tango.
2008 WK
drill it.
Tango. is offline
post #3 of 7 Old 04-17-2013, 11:02 PM
trax95008
2006 XK Commander
I think the threaded insert has come loose from the sheet metal and is just spinning. Not sure what the solution is though...
trax95008 is offline
post #4 of 7 Old 04-18-2013, 05:45 AM
gamma500
2015 WK
Anyway you can get a pair of needle nose Vicegrips into the underside hole and fix the insert from spinning ? If so might be able to unscrew the Torx bolt or at least fix insert while drilling it out. I fixed a spinning Nutsert like this once by drilling an oblique hole through it into the body metal and screwing in a sheet metal screw.
gamma500 is offline
post #5 of 7 Old 04-18-2013, 04:52 PM Thread Starter
bmgrosso
2008 WK
Yea I think you might be right and neither am I..
I'll take a look and see if I can make this happen.
bmgrosso is offline
post #6 of 7 Old 04-18-2013, 04:57 PM
yzjwk
2005 WK
Drill a small hole in the insert on either side of the bolt head . then use some bent nose ring pliers to hold the insert while you unscrew the torx .(or small needle nose if you have as long as the ends will fit into the holes you drilled)
good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #7 of 7 Old 04-18-2013, 06:55 PM
modernblueWK
Can you pry the rack up to put tension on the nutsert. Then try unscrewing it?
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
