Help with removing the grill on a 06 GCL - JeepForum.com
post #1 of 10 Old 12-06-2007, 09:09 PM Thread Starter
paulie9
Hey all,
I have an 06 Grand Cherokee Lerado and I am trying to remove the factory grill so I can put some after market stuff on. My problem is that I don't know where the screws/bolts are hidden to make this happen! Any help is appreciated.
paulie9 is offline
post #2 of 10 Old 12-07-2007, 07:18 AM
T-Rated
T-Rated's Avatar
From memory, there's a row of push-in pins across the top when the hood is open. I think the air temperature sensor is clipped onto the grille, so you'll have to remove that before you pull it. Then I think it tilts out for removal, but there *may* be more push-in pins across the bottom, but I don't remember any.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #3 of 10 Old 12-07-2007, 10:10 AM
z_gilligan
2010 JK Wrangler
There is about 8 pushin clips along the top of the grill. The temp sensor is mounted on the radiator if I remember right. Just get a small screw driver and pry the middle clip out then pull the outer portion out. I just took the grill off about a month ago to put a K&N intake in.
Hope this helps
z_gilligan is offline
post #4 of 10 Old 12-07-2007, 10:39 AM
CEPCNC
2005 WK
there are 6 push pins across the top of the grill, use a flat head to pry up the pins then ease them up with a wide based flat head to completely remove them. the grill will come out if you pll the top out first then gently move the bottom portion back and forth to release the bottom tabs...there are 4 of those.
CEPCNC is offline
post #5 of 10 Old 12-07-2007, 03:13 PM Thread Starter
paulie9
Thanks everybody for the help, I seen those pins that you have mentioned but I am a chicken so I didn't want to touch them without hearing somebody say it first.
paulie9 is offline
post #6 of 10 Old 12-07-2007, 03:58 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
So ... how many of these push-pin thingies are we talking about here?
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #7 of 10 Old 12-07-2007, 04:08 PM
CEPCNC
2005 WK
no kidding....I wouldn;t have known if I hadn't just did a little modding to mine.
CEPCNC is offline
post #8 of 10 Old 12-07-2007, 07:47 PM
T-Rated
T-Rated's Avatar
All of them.
T-Rated is offline
post #9 of 10 Old 12-08-2007, 05:38 PM
z_gilligan
2010 JK Wrangler
I think there are like 8 or 9 just along the top though. Once they are all off pull the top of the grill toward you while pulling up.
post #10 of 10 Old 12-08-2007, 06:25 PM
tednelson83
mine has 6. im not a chicken and i pulled off the grill one day cause i was bored. than did it again 6 months ago to put on that monster trans oil cooler.
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
96 grill on a 93? LORDZJ93 ZJ Grand Cherokee Forum 1 12-15-2009 12:57 AM
'96-98 grill on a '93? wickerham ZJ Grand Cherokee Forum 3 10-06-2009 06:50 AM
Good Spray Paint For Chrome Grill - Black Grill coryg23 ZJ Grand Cherokee Forum 2 06-18-2009 09:56 PM
Grill Mod DSMjunkie ZJ Grand Cherokee Forum 20 11-06-2004 07:14 AM
Grill anyone? m3photo ZJ Grand Cherokee Forum 5 06-11-2004 10:55 AM
