Help removing adhesive tape from roof. - JeepForum.com
post #1 of 4 Old 04-13-2013, 02:42 PM Thread Starter
bmgrosso
2008 WK
I bought a jeep that didn't come with side rails for the roof so I just bought some online. I went to remove the pieces on top where the side rails go thinking it would be simply removing the screws only to find there is a track under them that is attached by this really sticky adhesive tape or something and I have no clue how to get that off.
The first picture is what I have now, then a picture of the track that is under them and finally a picture of the adhesive that I need help removing. Any advice would be really helpful.
2008 WK - 3.7L V6 - Magnaflow Exhaust
bmgrosso is offline
post #2 of 4 Old 04-13-2013, 02:52 PM
toycam
Hair dryer to heat it up and use your thumb to roll it off. Or use goo gone or wd40
| '05 4.7L V8 | OME HD | Matrix 4xGuard | 4xGuard Front Skid | 265/70/17 TreadWright M/Ts |
toycam is offline
post #3 of 4 Old 04-13-2013, 03:10 PM Thread Starter
bmgrosso
2008 WK
I'm not really having trouble getting the thicker stuff off but the really thin layer right at the beginning is what I can't get up. I'll try wd40.
bmgrosso is offline
post #4 of 4 Old 04-13-2013, 03:10 PM
colinzj
2006 WK
The instructions call for a 3M Stripe Off wheel, which is undoubtedly the easiest and least painless way to go about this. If you want to make short work of it then tossing a Stripe Off wheel in your power drill will do it.
If you've got a paint and body store in the area, they usually run around $25 or $30. Whether the time saved is worth that price is your decision.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
