HELP please: Replacing liftgate strut supports! - Page 3 - JeepForum.com
post #31 of 61 Old 10-19-2012, 04:11 PM
jeremyAZ
2006 WK
Here is the strut being screwed into the top part of the liftgate.
Silver 2006 WK 5.7l Hemi Overland ~70k miles
jeremyAZ is offline
post #32 of 61 Old 10-19-2012, 04:31 PM
R4TCHET
2005 WK
i just changed mine out, i have the same screw in ones and cross threaded one side. but my glass supports had the clip thing.
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #33 of 61 Old 10-20-2012, 09:30 PM
Beeracuda
2006 WK
I did mine this week. The mop handle I used was the perfect size to hold the lift gate up. I started the top about halfway and then started the bottom. It was no problem.
2006 Grand Cherokee Overland, bone stock...for now.
The Beeracuda: http://youtu.be/Kcp0sqG_03M
Beeracuda is offline
post #34 of 61 Old 10-21-2012, 08:40 AM
rsurran
Jeremy, that price was each, right? Struts on my WK are shot.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #35 of 61 Old 10-21-2012, 08:06 PM
Beeracuda
2006 WK
I paid about $11.00 each from www.rockauto.com. The total for the 2 liftgate struts, the 2 back glass struts and shipping was $55.90.
post #36 of 61 Old 10-22-2012, 09:20 AM
jeremyAZ
2006 WK
The price I paid was for the both of the struts plus shipping all-in.
jeremyAZ is offline
post #37 of 61 Old 10-22-2012, 10:35 AM
w1pf
Who, me?
w1pf's Avatar
2007 WK
Just did mine in the driveway at lunch. Pretty straightforward with all the hints here.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #38 of 61 Old 11-17-2012, 07:48 AM
cherokee271
solution I used with same problem
I encountered the same problem when I removed one strut from the liftgate. I needed to remove both struts from the liftgate which then allowed me to open the liftgate further and gain the extra half inch needed to install the new struts. Your problem may have been different.
cherokee271 is offline
post #39 of 61 Old 11-18-2012, 10:56 AM
eprovenzano
2005 WK
I just replaced mine... because I was unloading some stuff out of the rear of the Jeep. I opened the hatch and pushed it open, took out some tools and turned back to get something else, and then BAM... I hit my head on the hatch as it came down about 1/4 of the way... After the birdies cleared, I stopped at Advanced Auto and bought new struts...
It took 15 min to replace both. I removed one strut, and started the top bolt, and then pushed up on the hatch while I started the bottom bolt. Once the bolt was started I used a power driver to finish it off.
2012 Grand Cherokee Limited Wk2 (Momma's)
2005 Grand Cherokee Limited, WK, 4.7 V8 currently rolling on Cooper Discovery 265 70 17's, with 1.25" spacers.,installed an OME HD lift sourced through Kolak.
1996 XJ 6 inch lift on 33's (Son's)
eprovenzano is offline
post #40 of 61 Old 11-18-2012, 11:09 AM
mrnavy2
2008 XK Commander
Eproven. What part number did you get from AA?
mrnavy2 is offline
post #41 of 61 Old 01-03-2013, 06:16 AM
lsuber
2005 WK
I used some of the advice in this thread and replaced mine last night on my '05 WK. Took both of the old ones off, and once I did that, my liftgate went significantly farther up (relative to the length of the strut, I mean). Did it by myself, so the hardest part was holding the liftgate up at the just the right position to get the lower bolts aligned and started. Overall, not a difficult small project at all.
2005 WK Grand Cherokee, Rocky Mountain Edition, 4.7L V8 4x4 QTII
2006 XK Commander, 4.7L V8, 4x4 QTII
lsuber is offline
post #42 of 61 Old 02-13-2013, 01:27 PM
LordEnki
2006 WK
06 wk here.
I loosened the old ones a few turns, then had a helper hold the lift gate up. I removed both supports at the same time and then reinstalled them. Removing both supports gives all the room necessary to lift the hatch a little more for reinstallation. Had no problems and with the helper it took about 5 minutes total.
Bought at Canadian Tire, $29.99 each.
Good luck and use an extra set of hands.
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #43 of 61 Old 02-13-2013, 04:01 PM
bigphil76
2005 WK
I got mine off EBAY for 22 dollars.. Installed easily with my Beautiful wife holding the lift gate up. I replaced the Glass lifts to..
97 ZJ 4.0, 2005 WK Hemi, Khaki WK Club #50 !!!!!!!GO TAR HEELS!!!!!!!!
bigphil76 is offline
post #44 of 61 Old 03-03-2013, 02:35 PM
gjxj
thought some might find this useful -- i secured the top good then used a ratchet strap to pull it into alignment.
$11 each at rockauto, way cheapper than local places even after shipping.
gjxj is offline
post #45 of 61 Old 06-02-2013, 11:06 AM
phottomatt
2010 JK Wrangler
Just ordered a pair, will update later on install on '07 Limited.
Rock Auto
2007 JEEP GRAND CHEROKEE 5.7L V8 OHV
STRONGARM 6601 Lift Support $ 11.36 $ 0.00 2 $ 22.72
Shipping Priority Mail $ 5.43
Order Total $ 28.15
2010 Flame Red Sahara, Rough Country stubby bumper/winch, Body Armor rock sliders, stiff spring mod and RC 2.5" series II spacer lift (~3.5" total lift), 33X12.5 Duratracs on 15" MB72s.
2007 Grand Cherokee Limited, Red Rock, 5.7L HEMI
phottomatt is offline
WJ:Are the Liftgate and Hood supports the same for the 2000WJ Hampster ZJ Grand Cherokee Forum 4 12-16-2009 02:03 PM
Liftgate Supports/struts random155 ZJ Grand Cherokee Forum 10 03-02-2009 11:54 AM
what size torx bit for rear liftgate supports on a wj? jcool1985 ZJ Grand Cherokee Forum 5 11-16-2008 10:00 AM
Easy to replace liftgate supports? juanvaldez ZJ Grand Cherokee Forum 19 01-20-2005 07:43 PM
96 Rear liftgate supports jds4218 ZJ Grand Cherokee Forum 11 11-28-2004 07:22 AM
