help me decide on a lift? - JeepForum.com
post #1 of 77 Old 07-26-2013, 04:13 PM Thread Starter
816jared
2005 WK
me: '05 80k miles, all factory stuff
got a pretty good deal on these here: (255/75/17)
probably going to plasti-dip them
the shocks/struts that are on there now are obviously shot, so time to upgrade. I'm leaning OME HD as that seems the most proper. I'm also open to suggestions as it seems there are quite a few people with different shock/strut + (RC/RRO/daystar) type lifts and are very happy with them.
my jeep probably spends 95% of it's time on the pavement, I know that should have some impact on the decision.
Help! Please!
816jared is offline
post #2 of 77 Old 07-27-2013, 04:31 PM Thread Starter
816jared
2005 WK
well, hrm, well that didn't work out so well.
let's try this! does anybody have any convincing arguments on why I should go another route other than OME
help!
816jared is offline
post #3 of 77 Old 07-27-2013, 04:50 PM
Jeepforthewin
2010 JK Wrangler
OME is basically the best route to go for a full suspension lift other than the superlift. When it comes to the MD and HD it all depends on the person. If you want a softer ride go with MD. A stiffer ride? The HD is for you. Also if you plan on adding armour, winch, and all that fun stuff then id recommend the OME HD lift. Hope this helps!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #4 of 77 Old 07-27-2013, 10:47 PM Thread Starter
816jared
2005 WK
with 80k on there should I be replacing isolators as well? kind of seems like a no brainer, to me.
I've also got somebody telling me it would be a good idea to do these as well:
http://shop.advanceautoparts.com/web...roe_20740136-p
suggestions there?
816jared is offline
post #5 of 77 Old 07-27-2013, 10:59 PM
ca07wk
2007 WK
Go with the OME HD you wont regret it. Replace the coil isolators while your at it. I have the OME lift kit available check out crawloffroad.net
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #6 of 77 Old 07-27-2013, 11:36 PM Thread Starter
816jared
2005 WK
and those strut mounts? not something I should be replacing as well?
816jared is offline
post #7 of 77 Old 07-28-2013, 02:09 AM
sunoff
2010 WK
ome hd. ur at 7...8 hundred dollars ...superlift 3'000$ thats a big diffrence... my twenty cents
not stock WK and still working on it
Modified Superlift 6"
bunch of heavy crap
sunoff is offline
post #8 of 77 Old 07-28-2013, 08:52 AM Thread Starter
816jared
2005 WK
for sure, and $3k is a bit more than I'm looking to spend right now.
816jared is offline
post #9 of 77 Old 07-28-2013, 09:20 AM
Jeepforthewin
2010 JK Wrangler
3k for a superlift?? You're getting ripped off with that.
post #10 of 77 Old 07-28-2013, 09:38 AM
BoraBora
2015 JK Wrangler
OME! Since you're changing your struts and shocks anyways.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #11 of 77 Old 07-28-2013, 09:47 AM
Anon155
2005 WK
Welcome neighbor! I have the OME HD and love mine. Got it from Kolak, he had the cheapest price I could fine. Superlift is around 1,600 plus install which can run anywhere between 500-1000 depending on who you know. Or you could do it yourself and save the cash....If your stock equipment is pretty well shot, go with all new. It's better to replace it now, then wait until later. What engine size do you have? If your looking to run a stacked lift, as long as you don't go over 23" hub to fender measurements up front you should be good. And that will all depend on your engine size and amount of weight you're planning to put on as well. You may want to replace your sway bar bushings at the same time. Some have had problems with sounds/clunks after their install and usually thats the culprit. If you're looking for stock equipment replacement, go to rockauto.com they usually have cheaper prices than local places I've found.
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #12 of 77 Old 07-28-2013, 10:54 AM
ca07wk
2007 WK
$3000 that's outrageous, I sell the superlift with ERG for $1750 shipped
ca07wk is offline
post #13 of 77 Old 07-28-2013, 12:33 PM
DRCracker
2006 WK
I agree, my Hemi has 85K miles and the original shocks were shot too.
OME HD made it ride terrific and works well with the armor and matrix, etc.
Unless you're going with 35" tires, why lift it way up.
TC
MOLON LABE: 2006 WK Limited, Dark Khaki Pearl, 5.7 HEMI, QDII,
Console XDs-45acp, Billet Catch Can, Airaid CAI Tube,
1" Spacers, Steel Armadillo Sliders, Dark Khaki 4xGuard Front Skid,
Dark Khaki 2011 #9104 Wheels, Firestone Destination A/T 265/70/17's.
OME HD lift. Dark Khaki Matrix Brush Guard, Dark Khaki Painted Headlight Bezels.
Hemi Club #65 // Khaki WK Club #40
DRCracker is offline
post #14 of 77 Old 07-28-2013, 10:49 PM Thread Starter
816jared
2005 WK
I appreciate the input! My Jeep is a 4.7 Limited.
is the part on rockauto you were talking about RAYBESTOS Part # 5501588?
816jared is offline
post #15 of 77 Old 07-28-2013, 10:49 PM Thread Starter
816jared
2005 WK
TC
did you do isolators at the same time? if you did not and could do it again, would you?
816jared is offline
