help me before I shoot it! - JeepForum.com
post #1 of 15 Old 02-16-2014, 03:35 PM Thread Starter
babygirl25stl
Any help and advice would be much appreciated. I have a 99 Jeep Cherokee Laredo 4.0l with some issues. To start with it had the famous stalling and rough idle, driveway cut outs (you know the drill). Till finally it quit. Had fuel, had spark, had everything. Cranks and tries it best but wouldn't turn over. Ok. So tested camshaft sensors, throttle position sensor, ignition coil packs (rail), I still had spark and fuel. But just in case did a fuel test. So last night I read about the pcm/ecu getting grounded out or the other famous soldering fix. Ecu was fine, reinstalled. Now today no spark. No fuel.. I'm at a total loss of what to do now.
babygirl25stl is offline
post #2 of 15 Old 02-16-2014, 03:42 PM
pmdowd6
You posted this in the wrong section. Try posting in the WJ section if you want some real answers
pmdowd6 is offline
post #3 of 15 Old 02-16-2014, 03:44 PM
james_2k
2003 WJ
did you check the IAC at any point? it gave my 4.0 jeep rough idle and lots of cut outs for a time too.
though that wont affect the new problems i guess
james_2k is offline
post #4 of 15 Old 02-16-2014, 04:04 PM Thread Starter
babygirl25stl
Forgive me for I have sinned. Thank you
post #5 of 15 Old 02-16-2014, 04:07 PM Thread Starter
babygirl25stl
True, I did check and clean the AIC before this new stuff. Replaced all sensors and cleaned contacts. Tested with multimeter as well. I'm really going crazy here. I have chased every possible Avenue that could be. Till I wound up with no spark and no fuel. Just checked the Relays as well. Possible the pcm fried out?
post #6 of 15 Old 02-16-2014, 04:12 PM
james_2k
2003 WJ
possibly. there are guys with lots of experience in the 4.0 so i hope that they will come and help. dont give up!
james_2k is offline
post #7 of 15 Old 02-16-2014, 04:16 PM Thread Starter
babygirl25stl
Thank you! Encouragement is all I have left. I was so desperate to get help, darn the luck I would post in the wrong section
post #8 of 15 Old 02-16-2014, 04:35 PM
paroxysym
2007 WK
Yea is go IAC, it's a culprit for rough idle. Is remove your throttle body, take all the sensors off and hit yen throttle body with one cleaner and hit the IAC with some too.
May be dumb, but how's your battery?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #9 of 15 Old 02-16-2014, 04:39 PM Thread Starter
babygirl25stl
Oh never a dumb suggestion! I have been continuously checking the battery. I even checked fuses and relays... just on the off chance that something ridiculous would slip pass me. But see after reinstalling my pcu.. guess what. No gages. Wriggled around everything, double checked connections.. still no gages! What have I done?
post #10 of 15 Old 02-16-2014, 04:42 PM Thread Starter
babygirl25stl
Btw I forgotten to mention I even replaced the IAC after it was cleaned... just in case it was a failure.
post #11 of 15 Old 02-16-2014, 04:51 PM
tom19511
2014 WK
You said you had the camshaft sensor changed? How about the crankshaft sensor. I had the same problem with my WK> It fixed the problem.
Good luck!!
Tom
tom19511 is offline
post #12 of 15 Old 02-16-2014, 04:57 PM Thread Starter
babygirl25stl
Good luck!!
Yes Sir. Here is a complete list of what I have done.
Catalytic converter
Fuel filter
crank shafts sensor x2
Coil pack
IAC
cam shaft sensor
Compression test
pcm contacts checked
post #13 of 15 Old 02-16-2014, 05:05 PM
paroxysym
2007 WK
Shoot it.... Jk
You checked all the grounds?
OEM+
post #14 of 15 Old 02-16-2014, 05:09 PM Thread Starter
babygirl25stl
Shoot it.... Jk
Yup. Checked grounds.. checked for resistance and ohms in all wires and connections. Figured I had a pinched or damaged wire some where. All cam out good. New spark plugs and was getting spark and fuel till I pulled the pcm out and re installed. Checked all grounds today and put new crank shaft sensor again for the second time, now no fuel... no spark and no gages
post #15 of 15 Old 02-17-2014, 11:20 AM
tom19511
2014 WK
In these forums there is a thread about the yellow wire on the starter. When it comes loose or corroded. the Jeep will not start..
Tom
tom19511 is offline
