Help with maintenance question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Help with maintenance question
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 04-29-2014, 09:36 AM   #1
colo970
Ok I'm thinking about having the transmission worked on. I want to have the transmission flushed and have the filter and gasket replaced as well. I'm looking at $279 for this to be done. I'm currently at 102xxx miles and have not had this done since I bought the jeep back in 2012. I dint do any towing at all. Is the price right and should I have this done.
Sent from AutoGuide.com Free App
colo970 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2014, 10:10 AM   #2
brianj08
2005 WK
just had my transmission fluid drained and the two filters replaced and also filled back up with mopar atf +4 fluid for only 129$ probably 150 after taxed and disposal. the 200$ sounds expensive.
Also, can i suggest you only drain it and not flush it. when you flush it there is the potential for some sediment in there that is in the gears from the years of use to be flushed out and loosening things up. this could actually make the car drive worse from what I am reading.
just drain fluid, replace both filters and refill with new OEM fluid.
brianj08 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2014, 10:13 AM   #3
cobra259
2006 WK
I would just drop the pan do the filter and the 6 quarts you will lose. Unless you can get it done cheaper.
2006 GC Limited 5.7 Hemi Stone White BT c/can Mopar cold air
1995 Cobra Mustang Procharged
cobra259 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2014, 03:48 PM   #4
10Xk
2014 WK
I would not change it unless it is burnt or contaminated.
10Xk is offline   Reply With Quote Quick reply to this message
Unread 04-29-2014, 06:26 PM   #5
colo970
Is there a how to on how to do it? My only issue is limited space and tools
Unread 04-29-2014, 06:44 PM   #6
colo970
Also where can I purchase the filters
Unread 04-30-2014, 01:54 AM   #7
twistedlizard72
2007 WK
Disregard my post. It was pertaining to 545RFE Trans.
Kevin K.
WANTED: Steel Armadillo Sliders/Rock rails & Rola roof basket/rack
twistedlizard72 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 06:32 AM   #8
caulk04
2008 WK
What engine? V6 and SRT models use the NAG1 Merc trans while the other V8 models use the 5-45RFE Chrysler trans.
08 5.7 Limited - Intake - Exhaust - SC Tuner - BT catch can - 5100's - white LED dash and lighting
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 08:11 AM   #9
colo970
I have the v6. What kind of oil for the tranny should I get and 6 qts ok? Also is there a how to on doing this.
Unread 04-30-2014, 08:19 AM   #10
ggt1_02
2009 WK
You can not change the fluid in a V6 tranny yourself, it must be serviced by some one with the proper equipment.
09 WK Limited 5.7L QDII | SRT Intake Tube | BT Catch Can
ggt1_02 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 09:30 AM   #11
colo970
Why is that though isn't it just as simple as draining oil dropping oil pan replacing filters putting pan back on and filling up tranny from the dipstick location.
Unread 04-30-2014, 09:37 AM   #12
modernblueWK
Because you do not have a dipstick to check the level. They use a machine to check the level. Centennial jeep on arapahoe did a friend's trans service for $180 just 2 weeks ago. Might be worth the drive.
2008 WK 4.7 245/70-17 Grabber AT2 Magnflow G2 MLL's RC Lift 4xguard Steel Armadillo
Blue WK club #4
modernblueWK is online now   Reply With Quote Quick reply to this message
Unread 04-30-2014, 09:40 AM   #13
cobra259
2006 WK
Or you can also buy yourself a dipstick..
Unread 04-30-2014, 09:46 AM   #14
colo970
I have a buddy who is gonna give me one he bought awhile ago for his jeep but ended up selling it. So then I'll be able to do it then? Are there any how to on doing this job?
Unread 04-30-2014, 09:46 AM   #15
modernblueWK
I have the 545rfe trans, different than yours but just for comparison: my mopar filters were $47 from the dealer. 8 qts of atf4 at $8 each =$111 factor in the cost of the dipstick and your time. It may be better to pay somebody to do it. Btw i do all my own maintenance otherwise on 3 vehicles. Some jobs are worth paying someone to do. Messy as well.
Blue WK club #4
