Help With Maintenance - JeepForum.com
post #1 of 2 Old 11-19-2008, 09:07 PM Thread Starter
JOHNRAMBO
Hey guys I just bought my first JEEP!!! A 2005 grand cherokee limited 4.7L.29K miles, Trail Rated, lots of options. I have a few maintenance questions. I am good with cars so I have to ask......
I have the Quadra-Track II system how much of a pain in the *** is it to change both differentials fluid and the x-fer case. should I do the trany now?
which spark plugs do you recommend?
What if any are the problems this vehicle commonly has?
Thanks in advance guys!!!!!!!
JOHNRAMBO is offline
post #2 of 2 Old 11-19-2008, 10:22 PM
robpp
Differentials no different than any other vehicle. Limited, you need the LSD additive. For the front diff, you need a 14MM allen. Be sure you can remove the fill before you remove the drain. Transfer case normal as well. Drain and fill bolts. Rear you need to remove the cover. Need soem RTV gasket maker to seal it up. Also, for the front, some get a oil pump, a cheap plastic one, make it a lot easier to fill.
FWIW: The search button is your frioend. Lots of info here.
Here's a maintenance shedule and parts:
http://www.wkjeeps.com/wk_maintenance.htm
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
Oil Changes – DIY Maintenance Indian WK Grand Cherokee & XK Commander Forum 14 11-09-2009 09:11 PM
4.0 I6 Maintenance amargill19 ZJ Grand Cherokee Forum 2 10-05-2008 02:59 AM
CRD maintenance tcmglx WK Grand Cherokee & XK Commander Forum 0 02-05-2008 11:29 PM
Maintenance twmattox ZJ Grand Cherokee Forum 5 02-20-2006 12:58 PM
i need all the maintenance help available... Derek33 ZJ Grand Cherokee Forum 2 06-18-2004 11:55 AM
