Help Fix Broken Seat? Pics - JeepForum.com
post #1 of 3 Old 08-30-2013, 10:50 AM Thread Starter
jbarrett
Hi Guys,
Wondering if anyone can tell me how to fix this. The side panel on my driver's seat is broken. There is a broken screw that I can see (since the paneling pulls away from the seat). From what I can tell, that screw is accessed be removing the plastic around the seat adjustment controls. Does anyone know how to do this? Just pop it off with a flathead? Thanks.
jbarrett is offline
post #2 of 3 Old 08-30-2013, 10:54 AM Thread Starter
jbarrett
Pic attached.
jbarrett is offline
post #3 of 3 Old 08-30-2013, 12:28 PM
Anon155
2005 WK
The seat control panel is held on by plastic clips that fasten to the backside of the piece that is pulling away. You can use a small flat head to get one started, then try to squeeze your hand in behind the big panel to pop the rest out. I noticed a screw was broken on mine when I first bought it. The larger panel is attached with screws that go into the metal frame of the seat, and you will probably need to put a couple larger screws through it once that access panel is removed.
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
