-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Help Fix Broken Seat? Pics (http://www.jeepforum.com/forum/f67/help-fix-broken-seat-pics-1569111/)
jbarrett 08-30-2013 11:50 AM
Hi Guys,
Wondering if anyone can tell me how to fix this. The side panel on my driver's seat is broken. There is a broken screw that I can see (since the paneling pulls away from the seat). From what I can tell, that screw is accessed be removing the plastic around the seat adjustment controls. Does anyone know how to do this? Just pop it off with a flathead? Thanks.
jbarrett 08-30-2013 11:54 AM
1 Attachment(s)
Pic attached.
Anon155 08-30-2013 01:28 PM
The seat control panel is held on by plastic clips that fasten to the backside of the piece that is pulling away. You can use a small flat head to get one started, then try to squeeze your hand in behind the big panel to pop the rest out. I noticed a screw was broken on mine when I first bought it. The larger panel is attached with screws that go into the metal frame of the seat, and you will probably need to put a couple larger screws through it once that access panel is removed.
The time now is 07:45 AM.
