New/used 06 wk, transmission over temp - JeepForum.com
post #1 of 6 Old 08-06-2013, 05:41 AM Thread Starter
Tdre977
2006 WK
New member here, been lurking for a few weeks to get some mod ideas.
Just got an 06 overland 5.7 with 40k miles, and here's where the fun begins....
It keeps popping an intermittent "transmission over temp" warning, seems to happen with the a/c going more often. I can hear the fan kick on when it does this, other than that it doesn't have drivability issues when it comes on.
Still under warranty, so it was at the dealership for 2 of the 4 weeks I've owned it. They replaced the trans temp sensor, test drove it and said all was well. Got it about 5 miles away and sure enough the "trans over temp" came back on, took it right back and now I'm waiting to hear back from them this morning.
I've done some searching and seen the other posts about this, a lot of them with no start issues along with it, but mines been running and starting fine.
Any thoughts? Anything I might be able to steer the mechanics to for this?
Thanks
Tom
Tdre977 is offline
post #2 of 6 Old 08-06-2013, 11:06 AM
Jeepforthewin
2010 JK Wrangler
If you do not have a scanner go to auto zone and have them check the system for codes. If you have a code just post it here and we can give you the details of the code or just type it into google. I would think you have a bad sensor somewhere seeing as the message displayed for you after only driving 5 miles which wouldnt be enough time for the transmission to get too hot.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 6 Old 08-06-2013, 05:34 PM Thread Starter
Tdre977
2006 WK
I would, but the dealership still has it. They said it was a bad trans temp sensor, did their diagnostics and said everything was functioning perfectly after changing it out.
They gave me a jeep compass as a loaner...killing me.
Tdre977 is offline
post #4 of 6 Old 08-06-2013, 09:03 PM
Jeepforthewin
2010 JK Wrangler
Ouch! Atleast it's still a jeep!.... Kinda haha. Keep us updated on what happens when you get her back!
post #5 of 6 Old 08-29-2013, 07:36 AM
chriscalcaterra
2006 WK
Tdre977:
Did you get your vehicle back? If so, what was the outcome? I am having a very, very similar issue and the dealer replaced the Transmission Solenoid Pack. As I was driving home, after the repair, I saw the dreaded "Transmission Over Temp" pop up on the EVIC and quickly disappear. I'm going to bring it back to them no Tuesday, but was wondering if you have had any luck with a successful repair.
Thanks,
Chris
2006 GC Overland | 5.7L Hemi w/QDII | 2'' BDS Lift | 31.5'' Bridgestone Revo 2's | SuperChips (87 Octane Tune) | Bilstein Shocks | Stock Skids | Magnaflow Muffler (11226) | Stillen Pads/Rotors | Kicker System |
chriscalcaterra is offline
post #6 of 6 Old 08-30-2013, 11:05 AM Thread Starter
Tdre977
2006 WK
Originally Posted by chriscalcaterra View Post
Tdre977:
Thanks,
Chris
Got her back a few weeks ago. I'm not entirely sure what the dealer did on the second go around. I had discussed with my service advisor many of the solutions I had seen online, including the inspection of the harness at the tranny, the connections at the starter, the check valve on the tranny cooler line and a reflash of the tcm. After getting it back I've driven it about 1500 miles and haven't had it return.
Good luck with it, I know how frustrating this was.
Tdre977 is offline
