Help Cruise control won't work - JeepForum.com
post #1 of 16 Old 04-05-2012, 08:57 PM Thread Starter
72cj5er
72cj5er's Avatar
1972 CJ5
My cruise control on our 2006 Grand will come on when you press the on/off switch on the steering wheel, however, as soon as you press "set" it goes off and won't come on again until you have shut the Jeep off and restart it.
You can have the thing on forever, longest I went was 10 miles before pressing set when the cruise dash light simply turns off and you can't get it to turn back on without a power cycle.
No idea, Ive checked all connections, tried the key trick to get codes, won't work either, and all vacuum hoses are accounted for. I tried getting auto zone to pull the codes but they said their scanner only pulls codes when the engine light is on, which it isn't on.
Im at a loss, everything works great BUT this and its confused me big time.
72 CJ5 Renegade
86 MJ Pickup W/Tilt bed
94 YJ Wrangler
04 LJ Unlimited Wrangler
never far from a good trail
Growing old is mandatory; growing up is optional!!
72cj5er is offline
post #2 of 16 Old 04-05-2012, 10:08 PM
Beezy03
2006 WK
Had this happen in our 06 WK and it ended up being the steering wheel control module. $1100 later and its works great. Might also try replacing the actual switches first, Have herd that is a common problem as well.
Beezy03 is offline
post #3 of 16 Old 04-06-2012, 04:45 AM
lbdyll
2006 WK
My 06 actually turned out to be the brake switch. Pretty cheap and easy to change.
2006 Jeep Grand Cherokee Laredo 2" RC lift, 245/75/17 Goodyear Authority, 1.25" Wheel Spacers, Home-made Grill, Custom Scratchs and dents
lbdyll is offline
post #4 of 16 Old 05-13-2012, 03:30 AM
justinmiller930
2011 WK
I've been having this same problem and have no idea what is going on with it. When I press the on/off on the steering wheel, the indicator shows that it is activated, but when I press set, most of the time nothing happens. Then all of the sudden it will work. Since this problem is intermittent it is hard to diagnose. This has been going on for quite sometime. I took it to the dealership where I bought it and let them know about. I told them about what has been going on. They looked at it and discovered that the cancellation wire was corroded, so they replaced it.
The dealership claimed that they fixed it, but it still keeps doing this same problem that it did before. Not sure what is going on.
Any help with this same issue would be greatly appreciated.
justinmiller930 is offline
post #5 of 16 Old 05-13-2012, 07:25 AM
croth
2005 WK
Clock spring behind the steering wheel? Just a thought!
Craig
croth is offline
post #6 of 16 Old 05-13-2012, 09:45 AM
modernblueWK
The actual stalk /switch went bad on mine. It would work intermittent then stopped working alltogether.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #7 of 16 Old 05-13-2012, 12:04 PM Thread Starter
72cj5er
72cj5er's Avatar
1972 CJ5
Is the cancellation wire something we can check and see? I'm open to try anything now
72 CJ5 Renegade
94 YJ Wrangler
72cj5er is offline
post #8 of 16 Old 05-13-2012, 01:23 PM
mykdee311
2005 WK
On other vehicles I've had similar issues, been solved a few times by replacing a fuse. This may not apply on our jeeps.
05 WK Limited, QDII, Hemi, Superchip, OME HD Lift, JBA UCA & disconnects, 4xGuard (Belly, Sliders, Rear Sliders, Diff), 255/75R17 on Moab's w/ 1.5" Spacer, Thule M.O.A.B. Basket
03 3500 Cummins, 79 Mustang 2.5T Stroker, 63 F250 428 4x4
mykdee311 is offline
post #9 of 16 Old 05-13-2012, 04:35 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
Also make sure your 'cancel' button isn't sticking.
Mine does, and if I don't notice it the cruise control does all kinds of wonky things (generally requiring a key-off-key-on to reset).
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #10 of 16 Old 08-17-2012, 08:19 PM
AlsJeep1
72cj5er, you ever find a fix? Mine is doing the same exact thing!
AlsJeep1 is offline
post #11 of 16 Old 08-18-2012, 01:55 AM
lbdyll
2006 WK
Like I said in my previous post try the brake light switch. Mine did the exact same thing as the op's. Cheap and easy fix.
lbdyll is offline
post #12 of 16 Old 08-18-2012, 04:42 PM
justinmiller930
2011 WK
I was having the same exact problem with mine. It would show on the dash that it was working, but wouldn't set.
The dealership said that the cancellation wire was corroded and was most likely the root of the problem.
Needless to say, it didn't fix the problem. I haven't had any problems with it lately, but haven't been using it that much.
post #13 of 16 Old 12-07-2013, 01:15 AM
justinmiller930
2011 WK
I'm having the same problem as before (again). Still not sure what's going on. It quit, and now a year later, it's doing it again.
It's only doing it intermittently.
post #14 of 16 Old 12-30-2013, 02:28 PM
AlsJeep1
I replaced the brake light switch, didn't do anything to help mine.
1981 CJ-7 & 2006 Grand Cherokee
1984 Cherokee (sold)
1986 CJ-7 (sold)
2004 Wrangler (sold)
AlsJeep1 is offline
post #15 of 16 Old 06-01-2014, 12:15 AM
DavidGT650R
I have an 09 Grand Cherokee having the same issue. I've been working on this for quite a while, I'm heading taking a trip from Texas to Georgia in a week and I was hoping to fix this. I checked for unplugged vacuum lines and honestly I couldn't find anything for the cruise control. Are there still vac lines for cruise?? I pulled the brake light switch and checked the continuity on it, I checked terminals 1-2, 3-4, and 5-6. They all showed the same resistance as a brand new one, switch engaged and disengaged, I'm starting to get agrivated with it. You can press the on-off cruise control switch and "cruise" will illuminate on the dash, pressing set will do nothing, however it will still continue to say "cruise" on the dash. Any thoughts or fixes? Is the cruise control system still vac driven? I can't find any diagrams for it. Any help would be appreciated, thanks a ton guys. Btw, I don't see any fuses or relays for cruise either
DavidGT650R is offline
Cruise control doesnt work? RUNVS ZJ Grand Cherokee Forum 11 11-08-2015 02:22 PM
Cruise control button doesnt work Candymancan ZJ Grand Cherokee Forum 6 10-18-2010 01:37 AM
cruise control doesnt work 2tone93zj ZJ Grand Cherokee Forum 6 10-02-2009 02:28 AM
WJ V8 cruise control doesnt work! katzonice69 ZJ Grand Cherokee Forum 13 09-14-2009 07:40 PM
cruise control doesnt work part 2 2tone93zj ZJ Grand Cherokee Forum 6 04-15-2005 11:21 PM
