help! can i put 33s on my 4.7? - JeepForum.com
post #1 of 11 Old 08-25-2012, 06:09 AM Thread Starter
patjacobs
i have a 06 wk with the 4.7 and a 2.5" front and 2" rear lift. i want to put my 33" tires on it. i dont really offroad so im not too worried about rubbing. is this possible?
patjacobs is offline
post #2 of 11 Old 08-25-2012, 07:33 AM
Shafer57
2006 WK
I don't have a lift so i can only answer part of your question. Off-roading is not the only blame for tire rub. When your driving down the street and turn, tires may rub the wheel well. If you have to go over large speed bumps there's a slight chance. Just keep in mind there are alot of factors that could play into the tires rubbing the wheel well. Not just offroading
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #3 of 11 Old 08-25-2012, 07:40 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Yes, it is possible. You will want to address your p/w's up front for sure and possibly the rear fender roll.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 11 Old 08-29-2012, 06:01 AM Thread Starter
patjacobs
what about if the tires are 13.5" wide!?
post #5 of 11 Old 08-29-2012, 07:11 AM
paroxysym
2007 WK
why do you need 13.5" wide tireS?
for that size tire... pinch welds front and rear, wheel spacers and i would look at a 4" lift.. something narrower, id keep it around 3"
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #6 of 11 Old 08-29-2012, 09:18 AM
sk1er18
2007 XK Commander
No wheel spacers.... you can't run 13.5" wide tires safely on stock wheels. OP will need at least 9" wide wheels for that tire.... most 9" wide wheels have 4.5" backspace which would cause major rubbing issues even with 31x10.5 tires.... and don't even think about a 10" wide wheel.
Conclusion:
33x13.5 = No, not without 4" lift + trimming.
-Matt
sk1er18 is offline
post #7 of 11 Old 08-29-2012, 09:20 AM
sk1er18
2007 XK Commander
For reference, 285/70/17 = 32.7x11.2 ..... look up the work that's been done to fit those tires on WKs.
-Matt
sk1er18 is offline
post #8 of 11 Old 08-29-2012, 10:17 AM Thread Starter
patjacobs
i guess im selling them then haha. i got them for free. so what is the largest tire i can get without a headache with 2" spacers ( i like the real wide look)
post #9 of 11 Old 08-29-2012, 10:18 AM Thread Starter
patjacobs
and the 2.5 front/2"rear lift
post #10 of 11 Old 08-29-2012, 10:29 AM
sk1er18
2007 XK Commander
2" wheel spacers and stock wheels?
265/70/17
.... or 285/70/17 with some extra work. I don't remember who all is running that setup but I'm sure a few guys here will post links for you.
-Matt
sk1er18 is offline
post #11 of 11 Old 08-29-2012, 12:15 PM
paroxysym
2007 WK
so let me ask the OP what lift are you running right now? honestly with a 285 i would run at minimum a 1" wheel spacer... it will kepe them flush with your fenders
personally i love the look of 33s and the 2" lift.. ill be going that route soon.
OEM+
