Help with an A/C Vent Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Help with an A/C Vent Issue
The Jeep Forum Discount is ON!CHASSIS SAVERô Labor Day 2 for 1 Sale!!!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 09-01-2015, 01:48 PM   #1
Swim3600
2006 WK
Question regarding A/C Vents
Hoping someone has run into this before or knows what the issue may be???
2006 GC Limited Hemi...
A/C blows nice and ice cold through the two driver side vents but blows basically warm through the passenger side vents. The little rear facing vents behind the center console blow a little cooler than the passenger side but what I would still consider warm.
Any help would be greatly appreciated! Thanks, in advance, for any input and replies.
--Mike
Swim3600 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:51 AM   #2
T1m
2006 WK
I had the same issue on my 4.7 and the was juice was low. Been working fine after I had it topped off.
T1m is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:02 PM   #3
Chirpz
2007 WK
Possibly an issue with your "Blend Door". I think there are some threads on it.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:16 PM   #4
Swim3600
2006 WK
Thanks for the reply. Man, I hope it is as simple as that!
Unread Yesterday, 12:17 PM   #5
Swim3600
2006 WK
Thank you for the idea. I will search for those threads as well. Thanks for the reply.
Unread Yesterday, 01:33 PM   #6
T1m
2006 WK
Be careful reading the blend door threads, I almost had myself convinced my issue was a blend door. I decided to do the easy thing first, take it to my mechanic and have the AC serviced. They evacuate the system then weigh the Freon, if you are low they will add more and add a colored die. That way, they can see if you have a leak somewhere.
Besides, I don't think there are any reported issues with the blend door on the WK, I believe it was the WJ that had it.
Unread Yesterday, 02:09 PM   #7
Swim3600
2006 WK
Thank you for taking the time to reply. Very good advice and the path I will be taking first.
Thanks again...Mike
