Help with 2007 Jeep Grand Cherokee Car Intermittently Not Starting/Alarm - JeepForum.com
post #1 of 9 Old 07-03-2013, 04:46 PM Thread Starter
bonanzajellybea
Hi,
I have been looking at this forum because I am having trouble with my Jeep not starting, and I'm far from home so I'm in a bit of a jam. If anyone can help, I'd greatly appreciate it. A few days ago, my Jeep Grand Cherokee Laredo (2007) would not start when I turned the key (all I would hear was a click and the engine wouldn't turn). 30-40 minutes later, it would start. This happened twice, and then we took it to a mechanic, who said that nothing was wrong with it and that he was able to start it 15 times in a row. We continued to drive for 2 days without incident. Today, it once again would not start for awhile, and also, the factory alarm on the car, which had never been on previously, was suddenly on and started going off when I tried to turn the engine on. Also, whenever I unlock or lock the car, there is now a beeping noise that wasn't there before and the car beeps several times when I lock the car using the key fob and the doors are closed.
1) Does anyone know if the alarm/car not starting are related, and what I should do (replaced key battery already based on advice on this forum)?
2) Additionally, is there a way I can permanently disable the factory alarm?
Thank you in advance for any help.
bonanzajellybea is offline
post #2 of 9 Old 07-05-2013, 09:43 AM
JKM
2005 WK
First question, how old is your battery? If the original I would start there as the WK is very sensitive to voltage levels. Don't bother testing if it's original, just replace it. It's either due or will soon let you down.
Assuming your battery is good, next culprit of the no-start issue is corrosion on the yellow wire at the starter solenoid. This cause a weak signal to the solenoid, which cause the soleniod not to activate the starter. Corrosion is very hard to see since the corrosion issue for many has been where the wire is crimped to the female blade terminal, which is covered and hard to see. Best to replace the terminal. I will send you a pm with directions for this. In the meantime when you get this no start issue you could crawl under the Jeep and tug on the yellow wire, which will often help make a connetion and start the Jeep.
JKM is offline
post #3 of 9 Old 07-17-2013, 08:57 AM
Gwizzar
2007 WK
Directions/Instructions for fixing yellow terminal for solenoid
Any chance you could email me the directions for fixing this issue? Thank you for your time! gwizzar@roadrunner.com
Gwizzar is offline
post #4 of 9 Old 07-17-2013, 11:00 AM
LJS8510
LJS8510's Avatar
2015 WK
I agree, if you have original battery, its your battery!
Change it you will need one soon anyway, (if its original).
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #5 of 9 Old 08-12-2013, 11:29 AM
Gwizzar
2007 WK
I own a 2008 Jeep Grand Cherokee Laredo - purchased in November of 2007.... it had the exact issues. The battery is factory-original and I followed JKM's advice regarding the yellow wire at the starter solenoid. I have not had a single problem (knock-knock) since fixing it on July 17th
|¯¯l,[___],
l---L--OlllllllO¬
=~~~==oo==
()_) ()_)--<>-)_) GW
Gwizzar is offline
post #6 of 9 Old 11-13-2013, 11:49 PM
kk52736
2007 WK
Please email me instruction on how to done the solenoid wire? My email is kk52736(at)hotmail(dot)com
Thanks
2007 Grand Cherokee Overland 5.7L HEMI
kk52736 is offline
post #7 of 9 Old 11-17-2013, 09:34 AM
JKM
2005 WK
sending to your email now
JKM is offline
post #8 of 9 Old 04-01-2015, 12:34 PM
Gorange
Hello,
Could you please also email the directions for the solenoid issue? 2007 Grand Cherokee 5.7L Hemi
thank you so much!
phrog1962@gmail.com
Gorange is offline
post #9 of 9 Old 04-03-2015, 01:19 PM
JKM
2005 WK
Just sent along to your email address. For others I have posted this many times, but here it is again.
What I did was simply buy a female blade terminal at the autoparts store and cut off the factory terminal on the yellow wire at the solenoid. There is not much slack so cut the wire right at the terminal. When installing the new terminal, put die-electric grease on the bare wire before crimping it. Also get some good shrink tubing (double wall if your autoparts store has it) and put a piece that covers the wire and up to the tip of the terminal, therefore creating a weatherproof terminal. Clean off the male blade terminal on the solenoid and cover with die-electric grease and also put some into the female end of the new terminal. Make sure it fits tightly onto the terminal end on the solenoid. While you're under the Jeep I would also remove the battery cable on the starter and clean it and apply die-electric grease. Ground cable to the engine is just above on the 3.7L V6 and you should do the same to it as well. While you're cleaning battery cables I would recommend cleaning the ones on the battery and also the one that grounds to the body under the hood. BTW, I did mine from underneath the front of the Jeep on axles stands (jack in place as a safty back-up). Leave it cool down as you will to get your arms around the exhaust. Not an easy place to work in so make sure you give yourself lots of time and patience.
JKM is offline
