Help - Page 3 - JeepForum.com
post #31 of 37 Old 07-07-2013, 08:56 PM Thread Starter
meredith
got another problem that happened today...went over a speed hump, wasnt speeding, doing about 20km..and now i have this clunking/vibrating/scraping noise coming from under the car...it doesnt do it all the time, every now and then..what could this be?
meredith is offline
post #32 of 37 Old 07-08-2013, 06:43 AM
Zlartibartfast
2007 WK
could be a long list of things - there are parts under the car that can fall down and drag ex: the plastic "debris guards" (can't call 'em skid plates) - someone should get under it and give it a close inpsection
Zlartibartfast is offline
post #33 of 37 Old 07-08-2013, 07:10 AM
tom58
donīt think itīs anything serious. check your skid plates, plastic or metal, sounds like something came loose
tom58 is offline
post #34 of 37 Old 07-08-2013, 12:50 PM
Mainsail
2005 WK
As for the battery; that sounds like mine when the battery quit. I think the plates inside the battery broke loose and were shorting together. When they were apart- all was well. When they touched- nightmare. On my way to get the battery replaced I had to stop for cash and determined to leave the jeep running to prevent any drama with starting it again. Pulled up to the bank, shut it off out of habit. D'oh! Needed a jump to get it going and then it ran like crap, lunging and surging, lights flashing, for the quarter mile to the Sears auto center. The Sears auto tech couldn't get it started with his jump-box to get it into the shop. I think they just pushed it in. New battery and all is 100% again.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #35 of 37 Old 07-08-2013, 02:06 PM
jjarvis0007
2005 WK
Check your brake lines back towards your rear diff. Mine fell down onto the driveshaft and caused a huge ruckus all under the Jeep.
It would only do it after hitting a bump and would go away after hitting another.
jjarvis0007 is offline
post #36 of 37 Old 07-08-2013, 10:22 PM Thread Starter
meredith
i think the hand brake cable has snapped as there is no tension in the handbrake whatsoever
meredith is offline
post #37 of 37 Old 07-10-2013, 07:25 PM
johnniebravo
2008 WK
My ebake cable does rub heavily on the passenger side of the rear differential. I use zip ties now to keep it up. The padding around the cable now has a deep groove in it. Crawl under and check if its been severed.
2008 CRD GC
johnniebravo is offline
