Help - Page 2 - JeepForum.com
post #16 of 37 Old 06-30-2013, 01:50 AM
tom58
even with a broken immobiliser it runs for 3 sec and than stops. its either the ignition lock or a bad connection on the starter.but if you say the radio died, i would also guess its the battery.
you say it was tested with a new batt from racv? did you take the old batt out and put the new one in, or was it connected with a jump lead??
tom58 is offline
post #17 of 37 Old 06-30-2013, 03:32 AM Thread Starter
meredith
Hubby just
told me it was tested with a jump lead and it was getting 13.7 volt
meredith is offline
post #18 of 37 Old 06-30-2013, 05:57 AM
tom58
it does not work like that. take the old batt. out,put a new one in. job done, wanna bet??
tom58 is offline
post #19 of 37 Old 06-30-2013, 06:16 AM
LJS8510
LJS8510's Avatar
2015 WK
I would agree try a new battery by replacing the old one.
It might work, but it is so easy to try it is worth doing it.
Your going to have to do this soon anyway.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #20 of 37 Old 06-30-2013, 05:08 PM Thread Starter
meredith
omg cant believe this....before hubby was going to change the battery he decided to clean all the terminals...now it starts like a dream..i cant believe the two mechanics i had look at my car didnt even suggest this, and my hubby isnt even a mechanic..all it was was a case of dirty terminals...thanks all for insisting it was the battery and nothing else..saved me a small fortune..
meredith is offline
post #21 of 37 Old 06-30-2013, 05:40 PM
modernblueWK
You still might need a new battery soon. They dont last forever.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #22 of 37 Old 06-30-2013, 06:02 PM Thread Starter
meredith
yeah, gonna buy a new battery just in case also
meredith is offline
post #23 of 37 Old 06-30-2013, 07:29 PM
johnniebravo
2008 WK
Mine lasted 5 years also, thing to remember with advice you get here, the majority of time we are speaking from experience.
2008 CRD GC
johnniebravo is offline
post #24 of 37 Old 06-30-2013, 07:55 PM
jjarvis0007
2005 WK
The shop I work at has more problems with loose battery connections more then anything. We also change out batteries like you would diapers on a 1 month old.
jjarvis0007 is offline
post #25 of 37 Old 07-01-2013, 06:27 AM Thread Starter
meredith
Thanks for all your help guys..much appreciated
meredith is offline
post #26 of 37 Old 07-01-2013, 04:03 PM
Walt
2008 WK
When you get a chance, check the small (I think yellow) wire on the starter motor. This connection also tends to corrode and cause similar symptoms. My premise is that if the main terminals were corroded, then this might be in the same shape also. Recommend you check it prior to Winter.
Don't forget to disconnect the negative main battery lead first.
Glad your issue was so simple (and cheap) to resolve.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #27 of 37 Old 07-01-2013, 11:39 PM Thread Starter
meredith
Actually Walt, when we first got the car about 14 months ago we had that exact problem with the yellow wire..sometimes the car would start sometimes it wouldnt..so i came on here and asked some questions...luckily my car was still under warranty because i took it back to the jeep dealer near me, and because he wouldnt listen to me about the wire business, he decided it was a computer thing and went ahead and changed the computer in the car...got the car back and within a week was doing the same thing...so i told him again to check the yellow wire which in turn he did and my problem was solved..I can tell you, people on here are much more knowledgable than the dealers here and i will always come here if i have a problem first
meredith is offline
post #28 of 37 Old 07-02-2013, 06:08 AM
tom58
well, about 10.000 useres in the jeep community, with say 1 hour of experience each, makes 10.000 hour of experience. and it´s actually a lot more.
tom58 is offline
post #29 of 37 Old 07-05-2013, 04:08 PM
Walt
2008 WK
Another satisfied JeepForum customer......................
It's a shame that we all are forced to learn so much detail about the foibles of our toys. Seems as though some dealers just cut-and-try at parts replacement, especially when they are under extended warranty.
Walt is offline
post #30 of 37 Old 07-06-2013, 12:07 AM
chuckerants
The OP is in a colder climate so the battery may last 5 years, but here in Phoenix where it was 120F last week and 110Fs this week, all my batteries last no more than 3 years before I start having problems. Gad it worked out ok.
chuckerants is offline
