help?!??!!!?! - JeepForum.com
post #1 of 22 Old 06-17-2011, 09:14 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
help?!??!!!?!
whats up.... my 05 jeep grand Cherokee limited 5.7l hemi has been sputtering as of late and also will cut off from time to time, it sounds like its gasping for air on start ups and the check engine light has been on for a week or so now. My cruise control will sometimes set but at other times wont allow me. also my esp system pops up on the dash and tells me it is disabled and this runs my rpms to high, i have carried to a neighborhood mechanic and machines said that it is possibly the crank sensor?!?! but he said to take it and see if the problem was in the wiring just looking for some help from some people who have maybe been there and know from experience im relatively new to my jeep i mean im only 16 any help is good help please and thanks
gsbtarheel is offline
post #2 of 22 Old 06-17-2011, 09:29 PM
sal-XK
2007 XK Commander
If he pulled the code and it said it was the crank sensor then it probably needs to be changed. It's not a difficult thing to do but I can't remember how much they are. You should do the key dance and see what code your jeep is spitting out post that so people can help. Or you can try a local auto parts store and have them pull the codes for you. Oddly enough I've heard those problems pop up before from a dying battery as well LOL so get the codes pulled. I think you can search youtube for jeep key dance if you need to. You basically turn the ignition from off to on I think its 4 times real quick on the 4th time stopping in the on position. But look it up to be sure.
sal-XK is offline
post #3 of 22 Old 06-17-2011, 09:33 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
thank you i have carried it to auto zone and had test run, the battery was producing its usually output, but some codes did come up that the guy there was not sure of and ill try the jeep key dance,, if i do complete it what exactly am i looking for?
post #4 of 22 Old 06-17-2011, 09:45 PM
sal-XK
2007 XK Commander
They should of gave you a print out with the codes he pulled up didn't matter if he knew what they were or not. In your EVIC screen it will show a code or test complete or something I haven't done it in a long time so that's why I recommend you watching the youtube video on how to do it. If you post the code or codes here we can look them up and maybe point you in the right direction or at least educate you so a shop don't take you for a ride.
sal-XK is offline
post #5 of 22 Old 06-17-2011, 09:47 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
that he did and it was 3 times not 4 for my particular model but thanks so much, it gave me P0315 P0300 P1417 P0339 P0335 and then done in that order any ideas on what these might mean?
post #6 of 22 Old 06-17-2011, 09:52 PM
sal-XK
2007 XK Commander
I would have to find my link to look those up. if no one beats me to it I'll post the link so you have it as well. I just have to find it again.
sal-XK is offline
post #7 of 22 Old 06-17-2011, 09:57 PM
sal-XK
2007 XK Commander
I'm on the wife's laptop my links aren't on here but I found some here http://www.obd-codes.com/trouble_codes/
sal-XK is offline
post #8 of 22 Old 06-17-2011, 09:57 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
thanks i just googled each individually and they lead me to jeep forum and most were related to crankshaft sensor beinga circuit malfunction and crankshaft in itself and one was a multiple cylinder misfire, in particular number 7 i believe
post #9 of 22 Old 06-17-2011, 09:59 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
most were directly related the the crank shaft sensor itself, and one was a cylinder misfire in particular number 7, this leads me to think replacing of the crankshaft sensor of possible the crankshaft itself could help.
post #10 of 22 Old 06-17-2011, 09:59 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
sorry about that
post #11 of 22 Old 06-17-2011, 10:04 PM
sal-XK
2007 XK Commander
I just read someone had this issue and they did there crank sensor them selves so let me see if I can find that thread just for you to read. But all those misfires would be related to your crank sensor failing.
sal-XK is offline
post #12 of 22 Old 06-17-2011, 10:10 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
oh okay i looked up potential prices most came back to under thirty bucks so thats not looking to bad
post #13 of 22 Old 06-17-2011, 10:23 PM
sal-XK
2007 XK Commander
I suck at life tonight I can't seem to find anything The way I see it is you have a bunch of misfires and the crank sensor code would explain all the misfires so that part probably is bad. I would recommend changing it your self and save some money. I'm sure someone with a manual or who has done it already can jump in and tell you how to do it. My manual is for the XK unless the hemi was unchanged from 2005 to 2007 my manual won't help.
sal-XK is offline
post #14 of 22 Old 06-17-2011, 10:27 PM Thread Starter
gsbtarheel
2005 FSJ Cherokee
thats okay could you maybe help me find prices i found one for 97$ because it being a hemi the standard one for under 30$ would not fit FML but anyways i'm just trying to make sure that i find the part i need.
post #15 of 22 Old 06-17-2011, 10:35 PM
sal-XK
2007 XK Commander
Check out RockAuto there prices are usually pretty darn good.
sal-XK is offline
5.7 liter , help needed
