Heavy Duty Ball Joint - JeepForum.com
post #1 of 9 Old 03-20-2009, 10:48 AM Thread Starter
phillyeaglekgd
I have read and/or been told by several people that any of the 2" BB kits will put significantly more wear and tear on your ball joints because of the change in angle caused by the lift. So I have 2 questions:
Have any of you with a 2"-3" lift had problems with premature ball joint failure?
Does anyone make any kind of heavy duty ball joint?
Thanks!
phillyeaglekgd is offline
post #2 of 9 Old 03-20-2009, 10:54 AM Thread Starter
phillyeaglekgd
Just found some adjustable ball joints on the Rocky Road site. Anyone have these. Do I really need them, or should I just wait until the stock ones fail to replace them?
post #3 of 9 Old 03-20-2009, 02:27 PM
Acidcold
2005 WK
Don't buy that junk! with 2'' you will not have any problems, i wheel my jeep hard and never had a problem with my 2.25'' lift. now that i have 4.5'' i had no choice but to upgrade to a chromoly UCA with a spherical ball joint and a grade 8 pin found on GetLost4x4.com
Acidcold is offline
post #4 of 9 Old 03-23-2009, 07:38 PM
CEPCNC
2005 WK
I second Carlos testimony on the HD upper control arm assemblies from GetLost.4X4...more pricey but you've got to pay to play my friend!
CEPCNC is offline
post #5 of 9 Old 03-23-2009, 08:02 PM
Texas WJ
Texas WJ's Avatar
2005 WK
With my 2" I have had no issues.
Texas WJ is offline
post #6 of 9 Old 03-23-2009, 08:32 PM
LJS8510
LJS8510's Avatar
2015 WK
Like others said you will not have a problem.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #7 of 9 Old 03-28-2009, 09:55 PM
rwmorrisonjr
2006 XK Commander
Go to www.getlost4x4.com. Ross is a Jeep Commander forum and is having these types of ball joints made for WK & XK owners to replace the OEM ones. I'm running them with my 2" lift and they're so much better than stock. They're really great with the 4" Superlift and help increase the articulation.
Here's the direct link: http://www.getlost4x4.com/tabid/55/C...3/Default.aspx
rwmorrisonjr is offline
post #8 of 9 Old 03-29-2009, 09:26 AM
LJS8510
LJS8510's Avatar
2015 WK
Do you have any squeaking or any other noises coming form them?
LJS8510 is offline
post #9 of 9 Old 03-29-2009, 11:36 AM
Acidcold
2005 WK
These UCA's are not made by Getlost, they are made by Camburg engineering and are sold threw Getlost only.
Acidcold is offline
heavy duty bumpers ... phitmein ZJ Grand Cherokee Forum 2 03-24-2009 09:59 PM
OME medium or heavy duty? drespecki ZJ Grand Cherokee Forum 5 12-03-2008 07:35 AM
Heavy Duty 42re lucky_logger6 ZJ Grand Cherokee Forum 7 08-31-2007 06:27 AM
Heavy Duty Tie Rod Replacement - Did you do it? IdahoZJGuy ZJ Grand Cherokee Forum 13 07-11-2007 01:37 PM
Heavy Duty Tie-Rods. Death-Mobile ZJ Grand Cherokee Forum 3 10-31-2004 07:34 PM
