Heated seats dont work.. Please help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Heated seats dont work.. Please help
THE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaSavvy Billet LED Tail LightsCurrie
Unread 12-20-2013, 09:28 PM   #1
Aclow33
2006 WK
For the life of me I cant find an answer the the WK's having this common problem.
Everyone says check the fuse..
What fuse is this? Where is it? What number is it?
If its not the fuse what else is it?
I need some help.
Aclow33 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 05:59 AM   #2
RUGLAYR
I saw a thread on here the other day with the same issue. The fix was to unplug the passenger side seat and it resets the system and seems to be the fix.
RUGLAYR is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 06:19 AM   #3
Blown7
I need some help.
Alot...
These vehicles are not designed like the "Old Days"
When you press the switch it sends a digital message to the instrument cluster.... the cluster sends a digital message to the heated seat module..
So it can be any number of things..some are relatively easy to check like a fuse others are "fuzzy" and require the use of factory tools to diagnose.
Start with a wiring diagram.. if those items don't work it's time for the dealer..
Blown7 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 08:31 AM   #4
Aclow33
2006 WK
Neither of the lights for the buttoms light up. For if that helps someone diagnose this problem..
Unread 12-21-2013, 10:19 AM   #5
Blown7
My guess is the switch itself..
Unread 12-21-2013, 11:56 AM   #6
Aclow33
2006 WK
What one do I unplug?
Theres like 5 plugs lol.
Unread 12-21-2013, 12:58 PM   #7
RUGLAYR
Unplug them all it won't hurt anything the only one I wouldn't unplug is the yellow one
Unread 01-08-2014, 07:23 AM   #8
R32R1
2006 WK
Just rolling through trying to find a fix for this, I disconnected the larger harness under the passenger seat, reconnected, and voila! my heated seats work!
R32R1 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2014, 10:21 AM   #9
budro574
2005 WK
Im a diesel tech for Chrysler and hooked my jeep up to the WiTech system through OBD2. I did a reset and a flash, it fixed all my problems.
budro574 is offline   Reply With Quote Quick reply to this message
Unread 09-27-2014, 06:40 PM   #10
fishinbama
2007 WK
This just happened to me. Unplugged the module under the passenger seat and replugged it. All working now.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, BuilderBill valve body
2013 VW Passat tdi, 6m
2005 GMC crew cab 5.3
fishinbama is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 07:24 PM   #11
ISUzj
2005 WK
just a word of warning, I had my heated seats flicker on and off for a few weeks, then had a battery drain that i couldn't find. tuned out my heated seat module was shorting out. so if you have issues... check that first.
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
My Build Thread Align your jeep yourself B N B#175
ISUzj is offline   Reply With Quote Quick reply to this message
