Headrest Problem - JeepForum.com
post #1 of 14 Old 06-21-2011, 02:55 AM Thread Starter
gimrie
Headrest Problem
Can't see any posts about this, but hopefully someone on here has come across this problem....
When I lower the rear seat on my 2006 Grand Cherokee the rear headrests flip down. When I raise the rear seat and push the passenger side headrest back to the upright position it stays in place, but the driver's side won't. It just drops back down again.
Seems like something might be disconnected inside the seat. Anybody have any ideas??
Thanks!
gimrie is offline
post #2 of 14 Old 06-21-2011, 07:42 AM
dcecr
2006 WK
same thing happened to me but on the opposite side. i had it fixed under warranty so unfortunately i dont recall what the exact problem was, di you check to to see if there was a TSB put out on this?
dcecr is offline
post #3 of 14 Old 01-07-2012, 12:22 PM
AndyTee
2002 KJ Liberty
I know this thread is a little old but I am in the same situation that the rear r.h side headrest will not reset with the seat back upright. Can anyone advise on how to fix this please
Many thanks
AndyT
AndyTee is offline
post #4 of 14 Old 01-07-2012, 12:42 PM
sebastien
2006 WK
same issue here...but rarely do i ever have the back seats up.
sebastien is offline
post #5 of 14 Old 01-09-2012, 04:45 AM Thread Starter
gimrie
Not an easy fix....
I did manage to fix this, but it was a painful process
I had to remove the rear seats, which is difficult do to the bolts that are used, but I managed it eventually. I then removed the headrest and seat cover from the broken seat, again, this isn't particularly easy. You don't need to remove the cover completely, just unzip the and pull it up as far as you can to expose the catch mechanism for the headrest at the top. The catch is triggered by a cable that runs to the bottom of the seat and I think this can become unattached, or the cable can snap. In my case the catch just appeared to have seized up. I lubricated it well and made sure everything was operating nice and smoothly then reassembled everything.
Took half a day and a few grazed knuckles to fix, but the problem hasn't re-occurred
Give me a shout if you need more details!
gimrie is offline
post #6 of 14 Old 01-09-2012, 09:23 AM
AndyTee
2002 KJ Liberty
Thanks for the info. I'm offshore at present but will look to try and fix it when I get home. I wasn't sure how it wotked but as you say its by a wire and latch mechanism..... I may just take a few photos as well and post my findings... unless I loose my temper and ruin it
Thanks again.
AndyT
AndyTee is offline
post #7 of 14 Old 04-24-2013, 09:33 AM
yellowrose3502
2006 WK
fix for floppy rear headrest in 2006 JGC
Ok, I have a 2006 Jeep GC, bought it used. I folded the back seats down and when I tried to raise them back up I got the dreaded floppy head rests.
Solution:
Look down the base of the headrest pole on mine it was the one closet to the center of the car. Find the pole with the spring running parallel to the headrest, just to the inside of the spring, towards the center of the seat, is the cable. The tip of the cable has a small nub on it. Seems when you lower the seat a metal piece, slightly smaller than the size of a dime, slides down the cable. When you raise the seat the piece of metal is suppose to ride back up the cable to let you manually prop the head rest back up. Chances are the metal piece to stuck about 1/2 inch down the cable. Now that you have located the tip of the cable spray WD40 on it. Open and close the seat a couple of time to get the lubricant down the cable and on to the piece of metal. The piece of metal will rise up to the tip of the cable and enable you to lock the headrest back into place.
yellowrose3502 is offline
post #8 of 14 Old 04-22-2014, 01:21 PM
kevsjeep
2006 WK
Solution:
This has just worked for me.
Kev
2006 Black WK Overland
#140 Black WK Club.
kevsjeep is offline
post #9 of 14 Old 06-02-2014, 05:30 AM
dallen789
Hi, I have the same problem . Dumb question, but how do you undo the zip? I can see the zip, but I can't zee the 'puller'? toa ctually undoe the zip . I dont want to force it open as I will have no way of doing it back up. any help much appreciated
dallen789 is offline
post #10 of 14 Old 06-16-2014, 01:57 PM
berviecanuck
2007 WK
I have same problem with rear headrest. See the zip but do not know how to undo. Bought a boroscope and can see some type of spring. Any suggestions to get into the rear seat
berviecanuck is offline
post #11 of 14 Old 06-17-2014, 01:55 AM
dallen789
Hi
I had the identical quesion . PMed two of the guys on here who had the same issue. They didn't take apart anything and simply sprayed WD40 down the headrest holes and put the seat up/down a few times. I did the same thing and it worked in seconds .
post #12 of 14 Old 06-18-2014, 12:08 PM
berviecanuck
2007 WK
Wd40
OK, will try it but did not ant the WD40 attacking the lining from the inside
post #13 of 14 Old 04-06-2015, 08:50 PM
68lizzay
2006 GC rear head rests
OMG, thank you so much, the WD40 worked!! I have kids and others in the car a lot and the floppy head rest were a huge problem! No more
68lizzay is offline
post #14 of 14 Old 10-26-2015, 04:28 PM
Moosepuck
Solution:
Just wanted to say THANK YOU!... best single post I've ever read. I could see the cable and the little lever and coil spring on it that was binding, a little WD-40 and prodding it with a flat blade a few times freed it up....... I wonder what's next with this little devil, seems to always give me something to do.
Moosepuck is offline
Rear Headrest Removal Wet Doggg WK Grand Cherokee & XK Commander Forum 3 02-14-2010 05:03 AM
TV/DVD - Overhead or Headrest? JeffR ZJ Grand Cherokee Forum 4 06-04-2008 05:42 PM
Headrest Monitors bullyyj WK Grand Cherokee & XK Commander Forum 1 01-04-2008 01:44 AM
Vizualogic headrest monitors wally_joyner WK Grand Cherokee & XK Commander Forum 1 06-27-2007 12:40 PM
Commander Headrest Melda WK Grand Cherokee & XK Commander Forum 0 12-13-2006 07:11 PM
