headlight upgrade - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > headlight upgrade
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 07-27-2014, 12:27 PM   #1
gregstudeny
headlight upgrade
I'm looking to improve my weak headlights on my 06 wk. I have converted to h4 on my tj and really like it. So what are you guys using?
gregstudeny is offline   Reply With Quote
Unread 07-27-2014, 12:52 PM   #2
scootr29
scootr29's Avatar
2008 WK
High Beam
http://www.rallylights.com/all/light....html?cat=1987
Low Beam
http://www.rallylights.com/all/light....html?cat=1926
You will need to make some slight modification to the plastic part of the HIR bulbs....
Silver WK Club Member #1
2008 CRD QT2
scootr29 is offline   Reply With Quote
Unread 07-27-2014, 02:13 PM   #3
gregstudeny
Cool thanks
Unread 07-27-2014, 04:21 PM   #4
Kolak
Vendor
Kolak's Avatar
A headlamp relay harness will assist in giving you the best possible output from your bulbs, be they the stock ones or aftermarket.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote
Unread 07-27-2014, 05:15 PM   #5
121ak
2007 WK
Saw some guys running the switchback LED lights in the turn signals.
Gives white light until you turn on the turn signal. Simple way of having more white light facing forward.
#nastywks RC 2" Lift, General Grabber AT2s, Moab Wheels, Rola Roof Rack, Hunters Brushguard
121ak is offline   Reply With Quote
Unread 07-27-2014, 05:56 PM   #6
gregstudeny
I'm assume you sell the one you are talking about. I will be looking for it.
Unread 07-27-2014, 06:27 PM   #7
Kolak
Vendor
Kolak's Avatar
Oh yes, I have a very nice relay harness available.
Unread 07-27-2014, 10:33 PM   #8
jtodaro
Is this the same kind/type of relay harness (Putco/EAAutoWorks H4) I run on my XJ? If so, I highly recommend it (and need to also pick one up for my WK). My XJ was night and day diff.
1996 Cherokee XJ - White, 4.0L, AW4, D30HP 8.25C 3.55, RE 3.5, 32x11.5x15. 300k Miles
2005 Grand Cherokee Limited WK - Black, 5.7 Hemi, 545RFE, 3.73
Black WK Club Member #122 | HEMI Club Member #87
jtodaro is offline   Reply With Quote
Unread 07-28-2014, 05:59 AM   #9
paroxysym
2007 WK
those who do run a harness, is it that much of a difference with a set of stock bulbs? or do you need to go with a silverstar or an upgraded bulb for the difference to be that significant?
also, i know the harness connects to the battery- but i ve seen and heard of harnesses running off the alternator for a higher power output?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote
Unread 07-28-2014, 06:30 AM   #10
bersh
2008 WK
I haven't installed a harness (yet) but I've run them on previous vehicles and they can make a huge difference. Voltage drop (or lack thereof) has an expodential effect on light output.
Also, don't waste your money on silverstar bulbs unless you get the real osram version. I'm sure it has been debated as much on this forum as every other auto forum I'm on, but the bottom line is the color and amount of light they put out combined with generally short lifespan and high cost is a waste of money. As mentioned get the HIR from Philips and you're good to go. Amazon had the origjnal (and to me best) high beam HIR for cheap a few weeks ago but not sure if they still have them.
bersh is offline   Reply With Quote
Unread 07-28-2014, 11:22 AM   #11
csacharuk
2005 WK
Look at Wagner for HIR Bulbs. They come in a generic "wagner" box but say Philips on the bulb. I replaced highs and lowes with the wagners ordered on Amazon for about $60 total. The difference is huge and they don't have that ricer look at all.
Blue 05 WK 3.7L | RC 2" BB | 265/70/17 GG AT2 | Bilstein 4600 HD (rear) | 1.25" Spacers | Rage Rack|
csacharuk is online now   Reply With Quote
Unread 07-28-2014, 04:26 PM   #12
imthehink
2005 WK
The best deal online:http://www.ebay.com/itm/PAIR-PHILIPS...ffdd66&vxp=mtr Bought mine from him about a year ago.
imthehink is offline   Reply With Quote
Unread 07-28-2014, 06:26 PM   #13
ggrassmid
How much for the harness?
ggrassmid is offline   Reply With Quote
Unread 07-28-2014, 09:46 PM   #14
Kolak
Vendor
Kolak's Avatar
Send me a PM here on the forum and I'll get right back to you with pricing.
