Has anyone pulled the front drivers seat apart? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Has anyone pulled the front drivers seat apart?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 05-15-2015, 05:05 PM   #1
Texas WJ
Texas WJ's Avatar
2005 WK
I found a set of front seats nearby that are cheap, and of course no photos are available.
My question is, if as I suspect the driver's side is also shot like mine, can the passenger side be swapped in its place instead? Are the seats themselves, minus the controls on the side interchangeable?
Would it be a safe assumption that the newer seats out of the an '08 or '09 would swap into my early '05? They look the same, but one never really knows until you dig into them.
Thanks for any help.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 05:45 PM   #2
colinzj
2006 WK
The seat bottom—cushion and upholstery—is identical across both sides. Nearly everything else is side-specific.
On that note, the seat pan that the bottom cushion and upholstery mount to is also side-specific. So have a pair of hog ring pliers and be prepared for some minor surgery.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 06:26 PM   #3
Texas WJ
Texas WJ's Avatar
2005 WK
Thank you very much! So, basically, I would have to pull the cover off the seat is what you're saying, right?
Hopefully it's in decent shape, and I don't have to pull it all apart.
