Had a GDE scare!!! (wasn't the GDE tune) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Had a GDE scare!!! (wasn't the GDE tune)
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 12-02-2013, 03:24 PM   #1
atarijedi
2008 WK
So I installed the GDE eco tune today. Everything went smoothly after a question about the "GRAND CHEROKEE (WH)" in the instructions which weren't on the flasher, it said "GRAND CHEROKEE (WK)", they are the same thing in case anyone is worried.
So I started the truck up right after the tune, sounded awesome, had more pull, great! Parked the truck in the driveway, go inside and watch some tv. Dad comes home, so I told him I wanted to swap in the driveway because I am going out early tomorrow.
Turn the fob... a click, and no start. Tried again, click, headlights flashed, cluster gauge flashed. I freaked the f*** out, thinking, did I just toast my ECU?
Dad comes up beside the truck, asks whats wrong, I show him, and he's like "Oh, that's the battery". Phew...
After a jump, went to see a friend and had the battery tested. Turns out the battery in the truck could only hold a charge for like, 5-7min or so, things could have been much worse if the battery went out whilst tuning!
Anyways, bought a new battery for it from NAPA. Happy day!
p.s. Fluids for this thing cost an arm and a leg. NAPA guy said Jeep stands for "just empty every pocket", well, when you are talking about fluids, that's the truth! Has to be done though.
atarijedi is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 04:17 PM   #2
yzjwk
2005 WK
Your pretty darn lucky you got through tuning it before your battery died .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 05:21 PM   #3
Shafer57
2006 WK
X2.
If you lose all power while re-writing a PCM map, etc. You can pretty much bank on a tow to dealer.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 09:10 PM   #4
Chirpz
2007 WK
WOW. Close call. People need to notice this and beware!!
[B]Chirpz[/B]
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
Unread 12-02-2013, 09:44 PM   #5
Shafer57
2006 WK
Agreed. My battery is good, but even with that, I still unplug and disconnect ANY extra accessories. Including radio, etc.
Unread 12-03-2013, 02:08 AM   #6
atarijedi
2008 WK
Totally, I am veryyyyyyyyy lucky.
Unread 12-03-2013, 05:41 AM   #7
Blue_Sassley
2008 WK
I agree, I make sure I have my blower motor off and everything. Reading a lot of the different TSB's with re programming I notice Chrysler calls for a range of voltage to be on the system during there re programs.
Blue
2008 Grand Cherokee Laredo CRD - QDII - GDE Tune Oct 2013 - DPF delete by tnadanzig
2002 Grand Cherokee Laredo 4.7L - ST - Stock (Wreaked)
1999 Grand Cherokee Laredo 4.0L - QTII - Stock
1997 Grand Cherokee Laredo 4.0L - ST - Stock (Wreaked)
Blue_Sassley is offline   Reply With Quote Quick reply to this message
