Had a GDE scare!!! (wasn't the GDE tune) - JeepForum.com
post #1 of 7 Old 12-02-2013, 03:24 PM Thread Starter
atarijedi
2008 WK
So I installed the GDE eco tune today. Everything went smoothly after a question about the "GRAND CHEROKEE (WH)" in the instructions which weren't on the flasher, it said "GRAND CHEROKEE (WK)", they are the same thing in case anyone is worried.
So I started the truck up right after the tune, sounded awesome, had more pull, great! Parked the truck in the driveway, go inside and watch some tv. Dad comes home, so I told him I wanted to swap in the driveway because I am going out early tomorrow.
Turn the fob... a click, and no start. Tried again, click, headlights flashed, cluster gauge flashed. I freaked the f*** out, thinking, did I just toast my ECU?
Dad comes up beside the truck, asks whats wrong, I show him, and he's like "Oh, that's the battery". Phew...
After a jump, went to see a friend and had the battery tested. Turns out the battery in the truck could only hold a charge for like, 5-7min or so, things could have been much worse if the battery went out whilst tuning!
Anyways, bought a new battery for it from NAPA. Happy day!
p.s. Fluids for this thing cost an arm and a leg. NAPA guy said Jeep stands for "just empty every pocket", well, when you are talking about fluids, that's the truth! Has to be done though.
atarijedi is offline
post #2 of 7 Old 12-02-2013, 04:17 PM
yzjwk
2005 WK
Your pretty darn lucky you got through tuning it before your battery died .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 7 Old 12-02-2013, 05:21 PM
Shafer57
2006 WK
X2.
If you lose all power while re-writing a PCM map, etc. You can pretty much bank on a tow to dealer.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #4 of 7 Old 12-02-2013, 09:10 PM
Chirpz
Chirpz's Avatar
2007 WK
WOW. Close call. People need to notice this and beware!!
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #5 of 7 Old 12-02-2013, 09:44 PM
Shafer57
2006 WK
Agreed. My battery is good, but even with that, I still unplug and disconnect ANY extra accessories. Including radio, etc.
Shafer57 is offline
post #6 of 7 Old 12-03-2013, 02:08 AM Thread Starter
atarijedi
2008 WK
Totally, I am veryyyyyyyyy lucky.
post #7 of 7 Old 12-03-2013, 05:41 AM
Blue_Sassley
2008 WK
I agree, I make sure I have my blower motor off and everything. Reading a lot of the different TSB's with re programming I notice Chrysler calls for a range of voltage to be on the system during there re programs.
Blue
2008 Grand Cherokee Laredo CRD - QDII - GDE Tune Oct 2013 - DPF delete by tnadanzig
2002 Grand Cherokee Laredo 4.7L - ST - Stock (Wreaked)
1999 Grand Cherokee Laredo 4.0L - QTII - Stock
1997 Grand Cherokee Laredo 4.0L - ST - Stock (Wreaked)
Blue_Sassley is offline
