Grrrreat...... - JeepForum.com
post #1 of 5 Old 04-11-2013, 07:28 AM Thread Starter
jamie1131
2003 WJ
Grrrreat......
Went to top up my tires with air in my lunch break which should have been a simple task until the end of the valve came off with the valve cap.....
jamie1131 is offline
post #2 of 5 Old 04-11-2013, 08:21 AM
Jeepforthewin
2010 JK Wrangler
thats no bueno. Do you have the TPMS sensors?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 5 Old 04-11-2013, 08:23 AM Thread Starter
jamie1131
2003 WJ
Yup! I guess this is a problem when you rely in the sensors and therefore don't remove the caps to check the pressures!
post #4 of 5 Old 04-11-2013, 08:25 AM
Jeepforthewin
2010 JK Wrangler
ouch! i had to pay 90 bucks to replace one of mine.
post #5 of 5 Old 04-11-2013, 08:57 AM
05WKinPA
2005 WK
Its a problem with the caps being screwed on too tight, combined with a bad design, using metal valve stems that easily corrode. Over 5 yrs of owning my WK, I've had to replace all 5 sensors. The stems crack and eventually won't hold air. Its an unbelieveably bad design. Fortunately they now make sensors with rubber stems.
Rocky Road & OME MD hybrid lift / AEV Pintlers / 32" BFG Mud Terrains / Four X Doctor rear diff guard / JBA UCA's / 4XGuard Belly Skid / Stillen cross drilled rotors
05WKinPA is offline
