Green Diesel Engineering tune for WK - Page 4 - JeepForum.com
 3Likes
post #46 of 88 Old 11-03-2011, 06:31 AM
TurboDiesel
2008 WK
i sent an email yesterday....still waiting on a reply..
TurboDiesel is offline
post #47 of 88 Old 11-03-2011, 07:16 AM
Red_Smoke
Originally Posted by jjt250 View Post
why didn't Jeep (or Mercedes) tune it like you do from the beginning?
2007 was the phase in of the "Tier 2" emissions standards to light-duty passenger cars, including your Grand Cherokee CRD. What this means is DaimlerChrysler (at the time) had to prove to the EPA that the emissions emitted from the tailpipe did not exceed specific limits set forth in the "Bin" category of the vehicle for both the 50,000mile point as well as "end of life". The tailpipe emission most closely watch in the diesel world is the NOx, which is a direct result of the combustion temperatures. Rich combustion = lower NOx, but worse fuel economy. Conversely, lean combustion (ie more air for every one part of fuel) will give better fuel economy at the expense of higher NOx.
Jeep didn't do it this way from the factory because they weren't allowed to. Are you going to notice the higher NOx with an aftermarket calibration? - Absolutely not. I don't have emissions data for the GDE calibration, but I'm guessing it takes it back to 2003-type levels, which is still clean in my opinion. Write your congressman and ask him to push an agenda of fuel economy vs. emissions regulations. This has historically been the direction of the European "Euro" regs (which is why their cars get 40+ mpg)
Also, I was looking into a DPF delete and using a tune from another company, but do you think a DPF delete would make much of a difference with this engine? Thanks!
The back pressure of the Jeep DPF is very low, with regeneration events only occurring every ≈750 miles. There's not a lot of fuel economy to gain here. In comparison, DPF regenerations on the Big 3 diesel trucks are more like every 60-200 miles, so there are bigger gains with delete kits on those vehicles.
My suggestion... go with the GDE calibration only, and enjoy the mileage gains and extra skinny pedal it gives you.
2007 WK CRD: DD @ 27mpg, tuned by Keith at GDE
1997 100" TJ: Cummins/NSG370/TeraNomore/37's and leaf springs - Gone!
2008 Rubi Unlimited: Gone!
Smashin' Punkin - 06 Rubi LJ, Cummins QSB3.3, work in progress
IndyORV
Red_Smoke is offline
post #48 of 88 Old 11-03-2011, 09:25 AM
p3busman
Re: the Inmotion tune. I put the stage 2 version in my '07 WK this past June. There is a very noticeable power improvement with this tune. I have not nailed down any real gain in fuel mileage as the tune was installed right at the beginning of some very hot weather, which ment I was running the AC all the time. My daily commute mileage before the tune was ~22.5 MPG. Mileage after the tune is the same but during the hottest summer on record. In the next month or so, I should get a better picture. Inmotion does state that their tune cuts back on EGR function however, without an exhaust gas analyzer, I have no way to verify this.
-P3
p3busman is offline
post #49 of 88 Old 11-03-2011, 09:31 AM
p3busman
Oh, forgot to ask (sorry my Xoom wouldn't edit the post above), is there a GDE tune for BMW 335d?
p3busman is offline
post #50 of 88 Old 11-03-2011, 06:38 PM
jjt250
2007 WK
Thanks for the info! I'm leaning towards GDE because it just seems safest and there are no complaints.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #51 of 88 Old 10-20-2013, 10:25 AM
Barney9304
2006 WK
This is the most talked about tuning for the CRD WK on this forum, can we get it here in the UK?
If not what tune does the forum suggest in the UK?
Barney9304 is offline
post #52 of 88 Old 10-20-2013, 05:08 PM
BAH101
2008 WK
Originally Posted by Barney9304
This is the most talked about tuning for the CRD WK on this forum, can we get it here in the UK? If not what tune does the forum suggest in the UK?
I believe Custom Spooling is in the UK, they have a tune also.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #53 of 88 Old 10-20-2013, 07:03 PM
TurboDiesel
2008 WK
dont see why u couldnt get it in the UK..
Valpacer has it and he is in Austrailia
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
post #54 of 88 Old 10-20-2013, 08:31 PM
Jeepforthewin
2010 JK Wrangler
Easiest way to find out would be to just give them a call and ask them! I agree though, you should be able to seeing as Valpacer has the tune.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #55 of 88 Old 10-21-2013, 02:40 AM
Cherokee30D
2007 WK
Hi Barney9304,
I too are from down under and are able to obtain the GDE tune easy enough.
From the information I have gathered, go for the Eco tune. No need for the Hot tune.
Cheers, Craig
Cherokee30D is offline
post #56 of 88 Old 10-21-2013, 03:08 AM
james_2k
2003 WJ
ive just ordered mine. we dont have a dpf so its a double bonus.
james_2k is offline
post #57 of 88 Old 10-21-2013, 08:12 AM
Barney9304
2006 WK
I thought we had a dpf? Bonus if not, I suppose it too much to hope that we don't have a swirl motor as well
post #58 of 88 Old 10-21-2013, 08:47 AM
james_2k
2003 WJ
we do not
but we do have swirl motors. (the gde tune disables it though!)
check your car out, this is a pic of mine,
this is where the dpf would be if we did have one.
james_2k is offline
post #59 of 88 Old 10-23-2013, 07:27 PM
revitup
Stock Boost Pressure Question
I've got an 2008 with 111,000 klms and just got the bad news yesturday. So I'm thinking of going with the GDE Eco tune, and possibly with the gutted DPF.
Does anyone know what the max stock boost pressure is (PSI) and what is the max Eco tune PSI?
I used to be a real turbo/tuner/tech guy. Stock max boosts are about 7-9 psi next upgrade, 12-14 PSI and go up from there. I'm guessing if the performance of the Eco Tune is significant we are looking at a boost of 12-14PSI... which is still OK with no intercooler.
revitup is offline
post #60 of 88 Old 10-23-2013, 08:01 PM
Valpacer
2007 WK
Might want to check on that, the 3.0crd runs at 22psi......... and has an intercooler
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
Low Sulfur Diesel/Diesel#2 in CRD and Break-in CRD Dawg WK Grand Cherokee & XK Commander Forum 23 07-20-2012 05:13 PM
anyone here experienced in engineering? reconvet88 ZJ Grand Cherokee Forum 22 03-12-2010 03:31 PM
extreme-engineering.com Windowsrookie ZJ Grand Cherokee Forum 2 07-23-2008 05:01 PM
Live Jeep Engineering Q/A RIGHT NOW! Keith WK Grand Cherokee & XK Commander Forum 0 11-28-2007 03:14 PM
anthony engineering evans1010 ZJ Grand Cherokee Forum 8 07-28-2006 10:18 PM
