Grand Cherokee Hemi hydro locked - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Grand Cherokee Hemi hydro locked
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-20-2015, 02:01 PM   #1
GrootJeepit
I own a 2005 Jeep GrandCherokee with the 5.7L Hemi v8. I few days ago I went through some deep water, possibly 2 feet or more. The engine stalled mid way in the water. I had to get towed out of the water and back to my buddy's house. The jeep threw 3 codes with Obd2 scanner: P0700, P0888 and P0562. The next day it wouldn't crank. So my buddy and I hooked up battery cables to give it a jump (Bad idea) I should have left it alone and taken it to a shop. It ended up cranking over started rattling and spit milky brown color (water/oil) out of the back passenger side of the engine (assuming right by the passenger exhaust manifold) the oil dipstick is completely dry.
Any ideas? I need to know of a good but inexpensive mechanic. I just hope my engine isn't completely blown. I live is the westminster/co broomfield area.
MILES.
GrootJeepit is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 04:23 PM   #2
rodneya
2008 WK
Sounds like you put a rod through the block. If so, you will need more than an inexpensive mechanic.
rodneya is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 08:38 PM   #3
modernblueWK
Sounds fubar'd to me. Where did you go?
2008 WK 4.7 245/70-17 Grabber AT2 Magnflow G2 MLL's RC Lift 4xguard Steel Armadillo
Blue WK club #4
modernblueWK is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:21 AM   #4
GrootJeepit
My buddy buddy lives on a ranch. Just went off the side of the road a little.
Unread 04-21-2015, 10:31 AM   #5
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
You better start sourcing a new motor - and a mechanic that can swap it in.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:45 AM   #6
whitejc4
Any pictures of the water or the resulting damage?
whitejc4 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:56 AM   #7
GrootJeepit
Not yet I have not seen it since Thursday. I am trying to find a good yet semi inexpensive mechanic to look at it. Can any of you guys recommend one... Around Westminster/Broomfield area?
Unread 04-21-2015, 12:29 PM   #8
Chirpz
Chirpz's Avatar
2007 WK
Yep. Sounds like a gonner to me.
Pull the spark plugs. Turn it over by hand with a wrench if possible. If it makes it two full rounds, then you can use the battery and do a compression test on each cylinder. Inspect the outside of the engine underneath and both sides using a flashlight and a lot of scrutiny. Drain the oil and see what you get....
Good luck.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 12:39 PM   #9
BonesWK
BonesWK's Avatar
2006 WK
Yikes, like others have said, sound like you blew a hole in your motor by trying to turn it over.
Begin the search, local junkyards etc for a motor.
Ryan
2006 Black WK Limited 4.7 4x4 QD II
Lift/Tires/Stuff
If you want to achieve greatness, stop asking for permission
BonesWK is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 03:02 PM   #10
Jtav2012
2005 WK
Take a flashlight and see if you can find the hole in your engine that shouldn't be there, lol
2005 5.7L WK Ltd. || Pre-N23 FDCM || Fastman TB || Airaid CAI
Jtav2012 is offline   Reply With Quote Quick reply to this message
