Got a Question on front Bilstein 5100s vs 4600s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Got a Question on front Bilstein 5100s vs 4600s
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! All Bilstein shocks & struts - Lowest Prices Ever and 1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 04-02-2015, 01:57 PM   #1
LouC
2007 WK
I have a pair of front 5100s and I measured how much more distance there is between the lower flange that fits into the clevis and the snap ring that supports the spring mount at the lowest setting. Bilstein says these lift it 3/4" on the lowest setting. It looks like the 5100 is 6/16ths or 3/8ths longer than the 5100 in this respect. If so, then how do they provide 3/4" of lift on the lowest setting vs the 4600?
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 02:41 PM   #2
luckyse7ens
2010 XK Commander
Interesting question. I have 5100's on my XK and can confirm that their claims are true as far as lift height. I know the 5100 is a longer shock than the 4600 as well. Not sure I have any sort of answer for you though.
Looks like you mean 4600 here I think. Should reduce some confusion.
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 02:48 PM   #3
Fast55
2010 WK
The length difference between the ring and flange isn't proportional to the lift gained. If you look at them, the max position isn't 2", but does give 2" of lift.
2010 WK Limited
Hemi, Volant, Superchips 3872, Bilstein 5100's, LED's, etc.
Fast55 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 09:47 PM   #4
caulk04
2008 WK
It functions on a lever. The shock mounts part-way between the hinge and the wheel...simple geometry.
08 5.7 Limited - Intake - Exhaust - SC Tuner - BT catch can - 5100's - white LED dash and lighting
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 05:18 AM   #5
LouC
2007 WK
yep that's what I meant.
Unread 04-03-2015, 05:59 AM   #6
hxdrummerxc
hxdrummerxc's Avatar
2008 WK
I'm assuming is the same reason why strut spacers give double the lift of their size. Like people stack a 1/4 inch strut spacer and get a 1/2 inch of lift. I never really thought about why though.
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 06:12 AM   #7
paroxysym
2007 WK
the 4600s and the 5100s have the same valving- I think the initial boost from the 4600s is more apparent on these WKs because theyre replacing shocks on a worn to hell suspension.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
