Got a check gauges message, and it went away. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Got a check gauges message, and it went away.
ZONE 4.25" combo lift for TJ available at Rockridge4wWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORRough Country Lift Kits and Parts!
Unread 10-28-2014, 12:21 PM   #1
CarsonKT
2006 WK
today after I "loaded" my son in the car I turned on the ignition and saw the check gauges message showed up, and all lights on dashboard were on....., above the odometer, all gears indicators showed like [P][N][R][D], I can't really remember the exact order.
I turned the key and the car started and stalled, so I rushed back and grab a pad checked all info about this message and ODB pull a U1411 code.
I also found that I can't use my remote key to lock the car, I tried both keys none of them worked
It started to rain and we have to cancel our plan and stay home, after I "unloaded" my son I returned back to the car and gave it a last try, and guess what? It started normally, but with check engine light on.
I checked again with ODB and still U1411 and I cleaned the code started the car again, this time everything works fine
what I've done recently to my car?
After not driving it for 3 months, the battery is dead when I came back home, so I replaced a battery.
Yesterday we travelled about 400KM on highway and everything was fine.
I did some google search and ppl say things like ignition switch, fuel sender, or even junction box (broken fuse?), where should I start to dig? Thanks.
CarsonKT is offline   Reply With Quote Quick reply to this message
Unread 10-28-2014, 12:28 PM   #2
caddydaddy
2007 WK
Since you recently changed the battery, I'd double check the cable connections to make sure they are tight.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
166,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:00 AM   #3
CarsonKT
2006 WK
thanks, I will double check the connections
