Good PSI - JeepForum.com
post #1 of 2 Old 09-21-2013, 08:41 AM Thread Starter
DarthJeep
2005 WK
Good PSI
Hey guys, got the lift put in this past weekend. What is a good ON-ROAD PSI for a set of 265/70/17 Hankook DynaPro's? I have them aired to 36PSI each. Just wondering what you all run?
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #2 of 2 Old 09-21-2013, 02:19 PM
BAH101
2008 WK
I got this from another thread on the forum.
Draw a line across your tire tread with chalk. Then, drive a few feet until some of the chalk is worn away. The chalk line should be worn away evenly over the length if your pressure is correct. If there is more worn in the center of the tread, you are over inflated. More worn on the outside portions, you are under inflated.
I tried it on my 265/70 17 silent armours and my ideal pressure is about 38psi.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
