Glow plug module test? - JeepForum.com
post #1 of 15 Old 12-15-2014, 12:28 PM Thread Starter
VANCRD
2007 WK
I have a 2008 WK CRD. Two months ago I got code P0671 - # 1 glow plug. I replaced this with Bosch code 80050 and cancelled the check engine light with my code reader. About two days later the light came on again - not showing both codes P0671 and P0672. I just kept driving it and the engine has had no trouble starting - I should mention I live in Vancouver, Canada which has a prety temperate climate and the car is stored indoors at night. Now I am about to make a trip through the mountains where it can get very cold so I replaced both # 1 and # 2 with the original Beru plugs. Sure enough 30 minutes after replacing these and cancelling the error codes with my code reader I am getting that light on again - with same codes. From what I have read here I am thinking that it might be the glow plug module but I am not getting a glow plug module error code. I am tempted to just replace it but I am wondering if there is a way that I can test it before doing that? I would hate to replace it for $200 and find out that that is not the problem. Any ideas anybody?
VANCRD is offline
post #2 of 15 Old 12-15-2014, 09:56 PM Thread Starter
VANCRD
2007 WK
Anybody out there?
VANCRD is offline
post #3 of 15 Old 12-16-2014, 06:36 AM
mathetes
2007 WK
I have an 07. My glow plug module went out at around 90,000 miles. It did trip the code though. Soon after that the glow plugs started to go, so I replaced them all @ 100,000. Not sure this helps, but others will chime in I'm sure.
cgkoon
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete,
EHM MOD,
mathetes is offline
post #4 of 15 Old 12-16-2014, 08:03 AM
safe+fit
The original is slightly different than the replacement, in appearance anyways. I'm not sure if it is more efficient or durable? However it certainly sounds like it does need to changed.
safe+fit is offline
post #5 of 15 Old 12-16-2014, 09:09 AM Thread Starter
VANCRD
2007 WK
OK guys, thanks. Guess I will just bite the bullet and try a new module. Hope that is the problem.
VANCRD is offline
post #6 of 15 Old 12-16-2014, 11:45 AM
furiousbudy
2008 WK
It will solve your problem, happened to me too!
2008 Grand Cherokee CRD Limited 185,000KM, Kendall 5W40 Euro
2007 18CK Pionneer Travel Trailer
furiousbudy is offline
post #7 of 15 Old 12-16-2014, 02:22 PM Thread Starter
VANCRD
2007 WK
Hi furious buddy. Same problem? Code on plugs but no code on module? Thanks for the reply and hope you're right!
VANCRD is offline
post #8 of 15 Old 03-03-2015, 07:30 AM
08CanuckCRD
2008 WK
I'm likely in the same boat with my 2008 CRD Limited. 174000km on it, still running 4 factory original plugs, so I guess they don't owe anyone anything! Had one replaced last Fall (Mopar) and one just last month (Bosch).
Yesterday the CEL came on; pulled codes; indicated Glow Plug #6 open circuit. Double checked with multimeter at module end of wiring to confirm. So either the new Bosch plug or the wiring running to it are faulty. Having it looked at today.
My guess is the module, as I don't think plugs should fail so quickly (remember I'm still running with 4 originals). Taking the WK to an independent Mercedes tech I just found locally. Hope he knows more than the Chrysler twits - I have to remind them every visit that the CRD is a DIESEL engine..... sigh.
2008 WK Grand Cherokee Limited 3.0L CRD TurboDiesel, QDII, Stock 245/60R18
08CanuckCRD is offline
post #9 of 15 Old 03-03-2015, 08:02 AM
Red_liner740
When my module failed i got no module codes, i got Glow plug #2 even after replacing it.
Red_liner740 is offline
post #10 of 15 Old 03-03-2015, 09:02 AM
traitor5150
This is the same module they use on the first 2 generations of duramax and they fail there too.
traitor5150 is offline
post #11 of 15 Old 03-03-2015, 10:37 AM
oldsmoke
2009 WK
Very interesting since I did have to replace the glow plug module on my 04 Duramax. Still original plugs as far as I know with 210,000Kms.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #12 of 15 Old 03-06-2015, 12:02 AM
Palak
2008 WK
Curious as well.. I have a feeling my module may be causing issues...
I have seen on other forums here to go through MB for this part.. it's 9x out of 10 cheaper there...
The new style unit has a different PN# if I remember correctly.. but giving them the old should still bring up the new... if it doesn't look any different than yours, look for a dealer/seller who has a new one and not just old stock.
Palak is offline
post #13 of 15 Old 03-06-2015, 06:22 AM
SSF556
2008 WK
Here is an online source for the module...
http://www.benzpartswholesale.com/OE...429005801.html
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #14 of 15 Old 03-08-2015, 10:33 AM
oldsmoke
2009 WK
Thanks guys. My Jeep has been running a little rough on startup lately although I have no fault codes showing. I will start shopping for a new module but the looney is down to .80 on the greenback these days and there are no deals online shopping in the US. The factory one sucked so may as well try the aftermarket.
oldsmoke is offline
post #15 of 15 Old 12-01-2015, 09:11 PM
omsok
omsok's Avatar
2007 WK
Did it work?
@vancrd
Give us a hint. Did it work? Did you buy a new module?
Where? MB or Mopar?
Price?
omsok is offline
