GDE Tune (Green Diesel Tune) - Page 68 - JeepForum.com
 1Likes
post #1006 of 1281 Old 12-01-2013, 10:07 AM
jediknight
2008 WK
Originally Posted by oldsmoke
Anyone know if our Jeeps have an egr cooling system? The new diesels all have this feature and my suspicion is that the egr cooler soon becomes plugged with soot effectively turning off the egr function but saving the rest of the intake tract from suffering the same fate. I am totally fishing here but how does MB cope with this problem?
Yes it does. We tend to forget that egr cooling system helps out in warming up the engine. Its a good thing especially in very cold weather, but there is a trade off in everything. MB cope with this with the oil (specialized engine oil... Like mobile 5w40 formula M ESP). It helps minimising soot, optimise life of dpf and other exhaust component.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #1007 of 1281 Old 12-01-2013, 12:01 PM
oldsmoke
2009 WK
Thanks Jedi, I understand that egr and dpf systems are engineered into modern diesel engine management systems. Although my Jeep seems to run nicer with more power since I have modified it, it doesn't seem to heat up as quickly in the cold weather. Why can't I have it all
May the force be with you.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #1008 of 1281 Old 12-01-2013, 03:50 PM
Red_liner740
Egr is nothing more than a mandated pollution remover. The faster engine warm up is a beneficial byproduct but the damage caused to the engine and $$$ it costs the owners huge. EPA doesn't give a hoot, they aren't paying it. How does reingesting soot into an engine beneficial in any form?! Why do we run air filters if we are forced to reingest exhaust gasses?
IMO I can't tell a diff between factory EGR function and Eco tune in terms of warmup time.
If u want even faster warm-up, plug it in at night with a timer like I do. Dollar to benefit its probably the best solution. It cuts down on warm up, lowers your fuel consumption, and lowers the start up damage. Remember you do more wear and tear to the engine during that first few seconds of start up and running than hundreds of hours running on clean warmed up oil.
Red_liner740 is offline
post #1009 of 1281 Old 12-06-2013, 03:19 PM
Chucknav
2007 WK
600 mile tank with EcoTune
I just had my first tank of purely interstate driving (except for maybe 20 miles) since installing the EcoTune and dpf delete pipe. I wasn't in a hurry, so I never exceeded 65 mph for the entire tank. I usually had the cruise set at 64. I got 602.1 miles on 21.698 gallons = 27.7 mpg. This is by far my best MPGs and total miles on a tank I have ever had with this vehicle. Speed kills with this Jeep. If I drive 70 mph, I think it only gets about 25 mpg.
I have been tracking all my fuel ups on Fuelly.com since the EcoTune. My wife and I have averaged 24.3 MPG over nearly 7000 miles. She brings the average down a little. I have driven it exclusively the last 4300 miles and my average is 25.2 MPG. I used to average about 21.5-22.0 mpg before the tune and the best tank average I ever had was just over 24 MPG. The tune definitely has helped my Jeep.
Chuck
2007 WK Limited CRD QDII
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #1010 of 1281 Old 12-06-2013, 03:56 PM
SSF556
2008 WK
Originally Posted by Chucknav
I just had my first tank of purely interstate driving (except for maybe 20 miles) since installing the EcoTune and dpf delete pipe. I wasn't in a hurry, so I never exceeded 65 mph for the entire tank. I usually had the cruise set at 64. I got 602.1 miles on 21.698 gallons = 27.7 mpg. This is by far my best MPGs and total miles on a tank I have ever had with this vehicle. Speed kills with this Jeep. If I drive 70 mph, I think it only gets about 25 mpg. I have been tracking all my fuel ups on Fuelly.com since the EcoTune. My wife and I have averaged 24.3 MPG over nearly 7000 miles. She brings the average down a little. I have driven it exclusively the last 4300 miles and my average is 25.2 MPG. I used to average about 21.5-22.0 mpg before the tune and the best tank average I ever had was just over 24 MPG. The tune definitely has helped my Jeep. Chuck
stock?
4x4?
4x2?
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #1011 of 1281 Old 12-06-2013, 08:10 PM
Chucknav
2007 WK
Originally Posted by scootr29 View Post
stock?
4x4?
4x2?
See sig block.
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #1012 of 1281 Old 12-06-2013, 09:00 PM
SSF556
2008 WK
See sig block.
OK...iPad/Tapatalk does not show sig lines....
2008 CRD QT2
SSF556 is offline
post #1013 of 1281 Old 12-08-2013, 08:38 PM
Chucknav
2007 WK
oh, sorry. It's a 4x4 QDII with 2" lift and 245/75-17 tires. The tires are 2" taller than stock, but the same width, so I don't think they hurt my fuel economy as much as taller and wider tires.
chuck
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #1014 of 1281 Old 12-08-2013, 09:14 PM
WKCRD757
2008 WK
chuck
Chuck,
have you adjusted your speedo for the bigger tires?
2008 Grand Cherokee Diesel - DPF Delete - GDE Eco Tune
WKCRD757 is offline
post #1015 of 1281 Old 12-09-2013, 11:41 AM
Chucknav
2007 WK
Originally Posted by WKCRD757 View Post
Chuck,
I have not adjusted my speedo or odometer for the larger tires. They are both off about 8-8.5%. I use my garmin gps for tank mileage. On this particular tank, the GPS mileage was 602 and the odometer said 557. I have also verified this with the mile markers on I-79 on my 125 mile interstate commute that I do about once per week. According to the mile markers, when my odometer says I have traveled 92 miles, I actually have went 100 miles.
Chuck
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #1016 of 1281 Old 12-09-2013, 06:29 PM
WKCRD757
2008 WK
That is impressive Chuck. I-79 is not exactly flat either! Do you have a build thread or photos of your Jeep? I'd love to see how it looks with those 245 / 75s
Jeff
WKCRD757 is offline
post #1017 of 1281 Old 12-14-2013, 07:54 AM
Chucknav
2007 WK
Jeff
Here are a couple of pics. One beside of a stock 4x4 limited in a parking lot. And, one with and without the front air dam.
Chuck
District 2-20120824-00127.jpg   District 2-20120824-00122.jpg   IMG-20131211-00382.jpg
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #1018 of 1281 Old 02-02-2014, 01:24 PM
james_2k
2003 WJ
just bought and installed the hot tune into the WK and i really like it.
its actually much nicer to drive on the curvy rural roads i live around, takes much less pedal to get up to speed and the extra power and tq is great too.
if i could choose it would be hot tune every day
james_2k is offline
post #1019 of 1281 Old 02-14-2014, 10:50 PM
Supermanbaja
2008 WK
Knocking/rattling noise after GDE Eco Tune
Originally Posted by GDE View Post
For those that have noticed combustion noise in the WK tune, please let me know the following:
coolant temp (cold, warming, or warm)
Altitude
rpm
load
I can adjust the main timing and pilot injection a bit in those zones to soften the noise. The switch over from quiet to loud is when one of the injection events is shut off and the base map switches.
Send us an email with your findings at support@greendieselengineering.com
Thanks
I will log the temp,rpm and send it to you.
Supermanbaja is offline
post #1020 of 1281 Old 02-16-2014, 09:37 AM
sshaughn
2008 WK
I still don't know how many of your are getting such good gas mileage?! I drive 50-50 freeway/city, I drive fairly conservatively, hardly run the AC, and over the course of the year average 20.5, I usually get 390-440 miles out of tank. I think my best tank on ECO was 520 all freeway, can anymore shed light on this.
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 12:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 05:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 10:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 06:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 12:45 PM
