GDE Tune (Green Diesel Tune) - Page 59 - JeepForum.com
 1Likes
post #871 of 1281 Old 08-22-2013, 06:48 AM
Zlartibartfast
2007 WK
I fill it and wait til I see the foam on the surface dissipate, so I can see the fuel level in the filler pipe. I know they tell you not to do that, but I want to be sure it is filled to the same level every time.
Zlartibartfast is offline
post #872 of 1281 Old 08-26-2013, 04:28 PM
Chucknav
2007 WK
2nd Tank results
Filled up for the second time since adding the GDE EcoTune. It wasn't a full tank, but the results are excellent. 178.1 miles/7.020 gallons = 25.4 MPG. Tank was filled to the top of the neck, as was the previous tank. Average since the tune so far over about 700 miles and 2 fill-ups is 24.1 MPG.
2007 WK Limited CRD QDII
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #873 of 1281 Old 08-27-2013, 10:17 AM
tigrevolador
2007 WK
Hey all, I'm from Red Deer AB; the wife and I recently drove to Sicamous, BC and back for a houseboating trip - our fuel consumption average into the mountains and back after GDE tune was 8.6L/100km = 27.35mpg US. The best I was able to attain prior to the GDE tune was around 10L/100km = 23.5mpg US. In KM / mi per tank, this works out to around 850km / 530mi depending on how close to empty I would it go. Also, we took a 10 day trip around the Kootenays with a bumper pull trailer (loaded up weight about 6000lbs) and averaged about 450km / 280mi per tank (right around 16L/100km = 15mpg). Not amazing by any means, but pretty damn good pulling a fully loaded trailer into the mountains. Prev best on flat land no hills no stopping was about 380km / 235mi per tank (18.9L/100km = 12.5mpg US). Am curious to see what a flat land straight road test will show now! Very impressed with GDE eco tune. Excellent in town driveability, torque comes on much better from low end, turbo doesn't act strangely anymore and comes on much smoother. A bit louder diesel noise now, though nobody I have shown around (I'm a real estate agent) and nobody from my family / friends has even noticed a sound level difference. 10/10 service from GDE also. Highly recommended.
tigrevolador is offline
post #874 of 1281 Old 08-30-2013, 10:19 AM
oldsmoke
2009 WK
Eco tune caution!!!
Make sure you are hanging on and pointed in a straight line before you nail it at low speeds! Don't even think about it on wet pavement! I had read that I would have torque like the Hemi but now I believe Are we sure the tranny can stand this kind of twist?
oldsmoke is offline
post #875 of 1281 Old 08-30-2013, 12:12 PM
jediknight
2008 WK
Well isn't it same tranny then the srt8?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #876 of 1281 Old 08-30-2013, 12:57 PM
Zlartibartfast
2007 WK
yes, the transmission can take it! make sure your O.S! handles are secure - now try out the Hot tune!
post #877 of 1281 Old 08-30-2013, 03:21 PM
oldsmoke
2009 WK
Hot Tune?
Yah, good idea, I will check my O.S. handles. You people with the Hot Tune must be depraved
oldsmoke is offline
post #878 of 1281 Old 08-30-2013, 03:58 PM
oldsmoke
2009 WK
Same Transmission as srt8?
Don't know about that but zfartblast claims to have torturetested it with the Hot Tune so that's good enuf for me.
oldsmoke is offline
post #879 of 1281 Old 09-01-2013, 06:39 PM
Chucknav
2007 WK
3rd fill-up since the tune.
My third fill-up after the EcoTune is in the books. It was a little lower than the previous tanks. I attribute that to a possible DPF regen. I don't have a gauge to tell me that, I just noticed the evic going down for a stretch of highway driving I did, when it should have been (normally) going up. Anyway, this tank was 337 miles on 15.050 gallons...22.4 MPG. There was some short periods of low speed utility trailer pulling (farm cleanup) in there as well. So, that didn't help either.
The overall total for the first 3 tanks is 1022 miles/43.46 gallons = 23.5 MPG. I am very pleased with the results of the GDE EcoTune. I would estimate these 3 tanks at somewhere between 60-70% highway driving. Before the ecotune, I would be lucky to get 21.0 under these same conditions. As a matter of fact, prior to getting the tune, I noted my last two fill-ups. Under the same type driving I got 20.5 and 20.1 mpgs. Looks like I am getting about 3 mpg better than before. I am excited to do an all highway tank to see what it will do. I used to get 22-23 on a highway trip pre-tune, so I'm hoping for 25+ now.
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #880 of 1281 Old 09-01-2013, 08:58 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Thanks for the info, Chucknav. Your mileage is very comparable to mine.
On a recent trip pulling our 17' camp trailer we got 17. Was very happy with that.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #881 of 1281 Old 09-18-2013, 08:50 PM
Chucknav
2007 WK
4 more tanks of data
I have some more data for y'all. We have filled up 4 more times since last I posted and here are the numbers: 1277.9 miles/55.012 gallons = 23.2 MPG. Totals since installing the GDE EcoTune are 2300 miles/98.47 gallons = 23.4 MPG. Not too shabby. I won't be sending my tune back to Keith for a refund. I'm very happy with his product.
PS. I've noticed that every 2nd or 3rd tank, my MPGs go down to about 22 or so. Damn DPF!
2" RR Lift
255/75-17 Duratracs
GDE Eco-Tune
Chucknav is offline
post #882 of 1281 Old 09-19-2013, 07:18 AM
Zlartibartfast
2007 WK
yeah I have jammed it hard enough to hit the boost limiter, slid through a couple of corners, basically "drove it like I stole it" on a few occasions - the trans holds up just fine. I think the Hot tune is safe enough.
However, as I experienced before, I'm getting about 1 - 1.5 MPG less than I get with the Eco tune. I guess the Hot tune is just too much fun for the right foot!
post #883 of 1281 Old 09-19-2013, 10:21 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Mileage Freaks...
Ok all you mileage freaks. Here is a report from my latest trip.
We drove 1078.9 Miles over 5 days pulling a RV trailer. Total weight under 10,000.
We mostly drove at 57MPH except in towns which were few in number. It was hilly about 70% of the time with a couple of long steep grades. Total engine running time was 35 hours and 25 Minutes. (We spent a lot of time idling while we hunted for nearby geocaches.) We used 72.54 gallons of fuel. Terrain was North Eastern Washington, mostly wide open spaces.
So....
We got 14.87 MPG for the trip.
We averaged 30.62 MPH for the trip (remember we idled a lot)
My best EVIC mileage was 19, and the low was 14.5. The Evic changed dramatically as the terrain and windage changed.
I have ECO tune and the DPF Delete.
Usually I get 17.4 pulling the trailer so this trip was down a bit due to the time spent idling and the hills and the wind. Overall, I was happy with it.
Chirpz
Chirpz is offline
post #884 of 1281 Old 09-21-2013, 08:47 PM
oldsmoke
2009 WK
My brother has a diesel WK and tows an RV trailer probably weighing 8000 lbs loaded. He has towed at highway speeds in some stiff headwinds with no problem. Says it's quite amazing how well the jeep handles it in 4th gear.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #885 of 1281 Old 09-22-2013, 08:51 AM
Zlartibartfast
2007 WK
My latest stats -
worst driving conditions of all. 10MPH hour-long freeway crawls, short grocery trips, test drives around the block, flat out WOT runs - also new 31" tires.
22.2 MPG calculated, 19 reported by EVIC.
that was about the BEST MPG I got from my Jeep ZJ 4.0 and my Ford Ranger 2.5.
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 12:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 05:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 10:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 06:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 12:45 PM
